Page 1 of 2
RasPi ZeroW :port8080 dead. New install[SOLVED]
Posted: Saturday 07 February 2026 20:36
by rabbit
System:
Raspberry Pi ZeroW, Raspbian Bookworm Lite. It is a new, headless installation, no hardware attached.
SSH is functional, but i am not sure if the port 8080 or 443 are opened.
wget 192.162.1.82:8080 is not answering.
sudo service domoticz.sh status
domoticz.service - LSB: Home Automation System
     Loaded: loaded (/etc/init.d/domoticz.sh; generated)
     Active: active (exited) since Sat 2026-02-07 19:54:02 CET; 7min ago
       Docs: man:systemd-sysv-generator(8)
    Process: 2666 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
        CPU: 331ms
Feb 07 19:54:00 haz11 systemd[1]: Starting domoticz.service - LSB: Home Automation System...
Feb 07 19:54:01 haz11 domoticz.sh[2666]: Time synchronized, starting Domoticz...
Feb 07 19:54:02 haz11 domoticz.sh[2666]: Illegal instruction                   <------------------!!!!
Feb 07 19:54:02 haz11 systemd[1]: Started domoticz.service - LSB: Home Automation System.
It seems to be a critical line:
Feb 07 19:54:02 haz11 domoticz.sh[2666]: Illegal instruction:
What is the problem there, and what is the solution?
Is the Pi Zero suitable for running domoticz?
If the current os or domoticz version is not suitable for the Pi Zero, which is the latest usable version?
Greetings to everyone and have nice Weekend
Re: RasPi ZeroW :port8080 dead. New install
Posted: Saturday 07 February 2026 23:23
by waltervl
If the CPU is armv6 it is not compatible for prebuild installations.
You can build it yourself and there are some external repositories that have a supported version eg: https://github.com/SjoerdNLD/Domoticz-Armv6
Posted: Sunday 08 February 2026 0:41
by rabbit
It is ARM11 with 516 Mbyte Ram.
Thank you for your quick answer.
Posted: Sunday 08 February 2026 6:29
by willemd
Pi zero w is armv6, not suitable for latest domoticz install.
Posted: Sunday 08 February 2026 15:20
by rabbit
Yes, i , or wikipedia was wrong:
cat /proc/cpuinfo:-->         model name      : ARMv6-compatible processor rev 7 (v6l)
After your proposal, I installed: domoticz_linux_armv7l.tgz.
But not works. It is not in the ist of running programs in "top" command.
Is there a compailed binary version of Domoticz available for download somewhere?
Posted: Sunday 08 February 2026 15:38
by waltervl
Read my previous answer, there is a link to armv6 builds.
Posted: Sunday 08 February 2026 17:52
by rabbit
After a new install: Rpi Trixi lite headless, and domoticz_linux_2024.4_armv6.tgz, i have some advancement.
Active: active (exited) since Sun 2026-02-08 17:21:24 CET; 5min ago
Process: 927 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
CPU: 105ms
Feb 08 17:21:24 haz11 systemd[1]: Starting domoticz.service - LSB: Home Automation System...
Feb 08 17:21:24 haz11 systemd[1]: Started domoticz.service - LSB: Home Automation System.
According to the status message, Domoticz has started, but it is not visible in "top" command's task list. No any error mesage.
Still not available from web browser.
Posted: Sunday 08 February 2026 18:14
by waltervl
What if you stop the service and start Domoticz manually with
./domoticz
See also https://wiki.domoticz.com/Troubleshooti ... _log_files
Posted: Sunday 08 February 2026 20:08
by rabbit
./domoticz
./domoticz: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory :(
Posted: Sunday 08 February 2026 23:08
by waltervl
Ok, so you probably are running an older version 2025.1?
That indeed needs libssl1 you have to search how to install that on Trixie. There are topics here on the forum about that.
Posted: Sunday 08 February 2026 23:26
by FireWizard
Hi, @rabbit,
Raspberry Pi Zero has an armv6 structure. So you have to use a version from the link, @waltervl provided in a previous post.
You installed Raspberry Pi OS Trixie, which has ssl3 installed.
So you have to install a Domoticz version, that also needs ssl3.
The version, you downloaded is 2024.4. That uses ssl1.1.
So download 2025.2 from Walters link or install ssl1.1 on Trixie.
Posted: Monday 09 February 2026 2:04
by rabbit
Still the same error: error while loading shared libraries: libssl.so.1.1
- Rasperry pi trixi / Domoticz 2025.2 armv6
same with Bookworm lite os.
- Domoticz --> wget https://github.com/SjoerdNLD/Domoticz-A ... _armv6.tgz.
The question is: what is the functioning os / domoticz pairing.
I would like to avoid downgrading ssl from 3.0 to 1.1 because I am afraid that other software requires version 3.0.
Could a symlink help?
Any other idea?
Posted: Monday 09 February 2026 12:12
by waltervl
You have to ask the build owner (from that other github repository)
For the Domoticz builds 2025.2 needs libssl3 so probably it is a setting of the build.
You can always try to build Domoticz for yourself: https://wiki.domoticz.com/Build_Domoticz_from_source
Posted: Monday 09 February 2026 12:15
by FireWizard
Hi @rabbit.
What does the following command show:
openssl version
In my case, I run Domoticz 2025. 2 on a small test system Raspberry Pi 1B+, which is also an armv6 device under Raspberry Pi OS 12 Bookworm.
It shows:
OpenSSL 3.0.18 30 Sep 2025 (Library: OpenSSL 3.0.18 30 Sep 2025)
On another computer with Debian 13 Trixie installed, it shows:
OpenSSL 3.5.4 30 Sep 2025 (Library: OpenSSL 3.5.4 30 Sep 2025)
So both Bookworm and Trixie gives you OpenSSL version 3. So nothing wrong.
And so version 2025.2 should work.
Are you sure that the correct Domoticz version has been installed?
Check this and otherwise follow the description at: https://www.baeldung.com/linux/openssl- ... ade-debian
Posted: Monday 09 February 2026 14:39
by rabbit
Openssl Version: OpenSSL 3.5.4 30 Sep 2025 (Library: OpenSSL 3.5.4 30 Sep 2025) But domoticz ask for libssl.so.1.1.
The downloaded binary is: "domoticz_linux_2025.2_armv6.tgz." this is the latest.
Domoticz asks for 3 missing libraries and i attempted a workaround over simlink:
libssl.so.3 ---------> libssl.so.1.1
libcrypto.so.3 -----> libcrypto.so.1.1
libusb-1.0.so.0.5.0> libusb-0.1.so.4
At first glance, the first error message disappears, but another one appears in its place.
Original err_msg: ./domoticz: error while loading shared libraries: libusb-0.1.so.4: cannot open shared object file: No such file or directory
The new error_msg:
./domoticz: /lib/libssl.so.1.1: version `OPENSSL_1_1_0' not found (required by ./domoticz)
./domoticz: /lib/libcrypto.so.1.1: version `OPENSSL_1_1_1' not found (required by ./domoticz)
./domoticz: /lib/libcrypto.so.1.1: version `OPENSSL_1_1_0' not found (required by ./domoticz)
The trick didn't work.
Compiling from source? Hm... I never attempted any compiling in linux.
Posted: Monday 09 February 2026 16:54
by FireWizard
Hi @rabbit,
Version 2025.2 does not require libssl 1.1. So you are starting the wrong version of Domoticz.
This is not a binary, but an archive file. Extract this file in your Domoticz folder and be sure you run this extracted Domoticz file.
Posted: Monday 09 February 2026 20:14
by rabbit
Hi @FireWizard,
The downloaded file was extrated and started, according to source webpage. The result was as described above.
(in my point of view this is a binary archiv not source. I apologize if I was not precise)
it seems that the problem is not domoticz specific, rather interaction between OS and Domoticz.
Compiling from source ? I neved tried it, and compiling on pi zero... im not sure if that is possible.
Im open for any new proposals.
Posted: Monday 09 February 2026 21:19
by rabbit
just to clarify: domoticz_linux_2025.2_armv6.tgz ask for libssl.so.1.1.
You can see it in the copied error messages.
Posted: Tuesday 10 February 2026 12:34
by FireWizard
Hello @rabbit,
If you are fully convinced that you have downloaded https://github.com/SjoerdNLD/Domoticz-A ... tag/2025.2
and that you extracted it in the correct location and, I think, you already created an issue at Github.
Correct or was it someone else.
I run 2025.2 on my test system, which is RPi 1B (armv6) with Bookworm and OpenSSL3. No issues.
Or install libssl1.1 in Bookworm (or Trixie, but not tested).
See my post in: viewtopic.php?p=326293&hilit=libusb+dev#p326293
Posted: Tuesday 10 February 2026 20:20
by rabbit
Hi, @Firewizard,
after a maiden install bookworm lite and domoticz_linux_2025.2_armv6.tgz, same result: Missing lib.
     Active: active (exited) since Tue 2026-02-10 19:54:31 CET; 18min ago
    Process: 1997 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
        CPU: 14ms
Feb 10 19:54:31 haz11 systemd[1]: Starting domoticz.service - LSB: Home Automation System...
Feb 10 19:54:31 haz11 systemd[1]: Started domoticz.service - LSB: Home Automation System.
After installing: libssl.1.1 and libusb-dev, and sudo ./updatebeta, regarding your post:
ARMv6 is not supported anymore... Please upgrade your hardware
It's amazing that it works for you, but not for me.
