Adding Zigbee smart plug - what do I do wrong?
Posted: Monday 02 February 2026 21:57
by manjh
I have lots of ZIgbee smartplugs, they all come into ZigbeeForDomoticz with four functions, for instance:
SP19 AutoPower
SP19 electric
SP19 AutoPower kWh
SP19 Voltage
The names are what I gave them in Domoticz.
Functions are on/off, ctual power usage, voltage, and total kWh. The units show up as "TS011F-plug".
I just purchased two more, and brought them into the Zigbee system in the usual way. They show up as "TS011F-plug".
But for some reason, they come in as simple switches: I can only switch on/off. The other three functions are not there.
Specifications of these plugs show that they should have full functions.
I tried to remove one and re-do the procedure, no luck.
Am I doing something wrong?
Re: Adding Zigbee smart plug - what do I do wrong?
Posted: Tuesday 03 February 2026 11:03
by manjh
Just to make things clearer: the new plugs work fine as switch, only the three special measuring values are missing!
Posted: Tuesday 03 February 2026 13:25
by waltervl
In the Z4D webgui, do the new plugs show up as certified?
Posted: Tuesday 03 February 2026 13:40
by manjh
waltervl wrote: Tuesday 03 February 2026 13:25 In the Z4D webgui, do the new plugs show up as certified?
I can see them as "optimized". Is that what you mean?
Posted: Tuesday 03 February 2026 13:52
by waltervl
manjh wrote: Tuesday 03 February 2026 13:40
Yes, that is what i meant.
Do you see for those new plugs also only one device widget mentioned in the Z4D webgui?
Posted: Tuesday 03 February 2026 16:54
by manjh
waltervl wrote: Tuesday 03 February 2026 13:52
Yes!
Posted: Tuesday 03 February 2026 17:08
by waltervl
Then it looks something has gone wrong with the pairing. You are on the latest stable Z4D release 7.1.026 ?
Better create a github issue and supply the export.json of your Z4D environment.
https://github.com/zigbeefordomoticz/Do ... bee/issues
Posted: Thursday 12 February 2026 23:08
by manjh
Problem has been solved with an update in the plugin.
Plugin support is excellent! 🙂
