Python plugin Battery level incorrect installation
sop723
Domoticz version: 2023.1
Post by sop723 »
The installation script provided for this plugin isn't correct if you already use a virtual python env.
In this case you must install the paho.mqtt extension into the python virtual env i.e using this command :
python3 -m pip install paho.mqtt -t /home/pi/Domoticz_Python_Environment
