I am going to use the homewizard water meter together with the the plug-in from eraser3.
My question is can you set the current water meter value in the plug-in?
Homewizard water meter plug-in question.
azonneveld
- Domoticz version: 2024.4
Re: Homewizard water meter plug-in question.
If not possible in the plugin, you can use the meter-offset in the devicejslegers wrote: Tuesday 27 January 2026 21:14 My question is can you set the current water meter value in the plug-in?
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe (sems&modbus) - open weather map - wol - BBQ detection - rsync backup - zendure
