dzvents scripts unstable after update to 17053
Posted: Monday 26 January 2026 12:48
by Gravityz
I recently needed to update to 17053 because i needed the new hue functionality(without crashing)
first glance is that everything works but i am experiencing weird things.
Scripts which have always worked now only partially work
some devices will trigger the script while other devices do not anymore
as triggers i have
Working
general waterflow
p1 smartmeter energy
lightswitch switch
Not working
temperature device
general text
so the temperature will change or the text will change, i see a new timestamp but it will not trigger the script anymore
when i add a testswitch to the devices the script does execute
e.g. THERMOSTAATSETPOINT is a temperature device, when i change it into the trestswitch device it works
it looks like dzvents is screwed up
i discovered this with a dummy thermostat which refuses to update with command
       if device.name == THERMOSTAATSETPOINT then
            local SetTemperature = domoticz.devices(THERMOSTAATSETPOINT).temperature
                --we update silent otherwise the script gets triggered again
                domoticz.devices(THERMOSTAAT).updateSetPoint(SetTemperature)
now i also discovered another script which refuses to switch a select device
    if (device.name =='Flair Ventilatie Mode' and device.text == 'Stand 3') then
        -- schakel naar modbus mode, Flair Ventilatie Selectie schakelt over naar huidige level(Stand 3)
        domoticz.devices('Flair Control Mode').switchSelector('Modbus Step')
so either the scripts are not triggered anymore or certain commands fail to work
Re: dzvents scripts unstable after update to 17053
Posted: Monday 09 February 2026 10:13
by IanDury
Do you perhaps use persistent data in your scripts?
See https://github.com/domoticz/domoticz/bl ... /README.md
Posted: Monday 09 February 2026 10:56
by Gravityz
yes i do.
i use variables to measure how much time has passed.
However the part of the script which actually uses these variables works perfectly and get triggered.
The part which is only waiting for a device trigger does not get triggered.
data = {
	    starttime = { initial = 0 },
	    timeractive = { initial = 0 },
Posted: Monday 09 February 2026 14:48
by IanDury
I have similar behavior now and then with switches not triggering dzVents scripts that use persistent data. After removing the corresponding data file of those scripts it works again.
Perhaps a good practice to always delete the data files when doing an upgrade or even with every new start of Domoticz.
Posted: Monday 09 February 2026 14:54
by Gravityz
sounds promising
at the moment i am back to old version 16782. when i have the courage to upgrade again i will surely do this.
thanks for the tip
it could also have something to do with this change
https://github.com/domoticz/domoticz/is ... 3867010221
gizmocuz mentions something about the eventsystem in this change
