Can't update 2025.2 (build 17005) to build 17030
Posted: Monday 12 January 2026 18:26
by pfloryann
hi,
I have tried several times to update Domoticz beta 2025.2 (build 17005) to build 17030 and the update does not complete - no errors.
Thank you!
Re: Can't update 2025.2 (build 17005) to build 17030
Posted: Monday 12 January 2026 22:42
Did you try it over webgui? Then you probably have this issue that seems not to be fixed yet.
viewtopic.php?t=44190
As a workaround you probably can just reboot your system to force a reboot of the updated Domoticz.
Running sudo ./updatebeta will also fix it.
Posted: Tuesday 13 January 2026 8:23
by pfloryann
I have tried and that's the result
>> Starting Domoticz beta Update
>> Script: updatebeta (Directory: /home/pi/domoticz)
>> Validating environment...
>> Environment validation passed (arch: aarch64, OS: linux)
>> Checking package dependencies...
>> All required packages are already installed
>> Running updated script - proceeding with installation...
>> Stopping Domoticz service...
>> Creating backup: backups/domoticz_backup_20260113_091642.tar.gz
tar: .: file changed as we read it
>> Backup creation failed!
Posted: Tuesday 13 January 2026 14:44
pfloryann wrote: Tuesday 13 January 2026 8:23
So why does this fail? Do you have a script regarding backups?
Is the disk full?
No access rights?
Do you see the file domoticz/backups/domoticz_backup_20260113_091642.tar.gz ?
Posted: Wednesday 14 January 2026 10:24
by pfloryann
I don't know why...This has not been a problem until now(2025.2 (build 17005)). There is space on the SD card...80%. domoticz_backup_20260113_091642.tar.gz exist.
Posted: Wednesday 14 January 2026 10:40
by pfloryann
So, i succeeded.
cd domoticz
sudo chmod +rx backups
sudo ./updatebeta
I hope it will be helpful to others.
Thank you!
