Design for comfort mode and switch for a Mitsubishi air conditioner
Posted: Sunday 11 January 2026 13:32
by floris74
@waltervl, thanks, i was to enthusiastic so i wrote it in Dutch. changed it.
Hi, I thought I’d share a small DIY project.
I have multiple air conditioners in my house, used for both heating and cooling, and for multiple users. These users are often away, so in that case their airco obviously doesn’t need to be on.
There are two scripts:
Airco Eettafel Operation Control
Determines HOW the airco should operate: mode (heating, cooling), fan speed, swing mode, etc.
If the temperature is within the comfort zone, the airco will not turn on.
Allows fine-tuning of setpoint, fan speed and swing mode.
Whether the airco is allowed to run at all is handled by the Airco Eettafel Power Control script.
-- Airco Eettafel - OPERATION CONTROL
-- Bepaalt HOE de airco moet werken, in welke modus (verwarmen, koelen, fan speed etc)
-- Als de temperatuur in de comfortzone zit, gaat de airco niet aan
-- Zorg voor finetuning qua setpoint en fan en swing modus
-- OF de airco moet werken, zie Airco Eettafel Power Control script
-- CONFIGURATIE
local IDX = {
    temp        = 3991, -- Temperatuur
    comfort     = 5268, -- Airco Comfort schakelaar (dummy, schakelaar voor de ruimte indien comfort gewenst)
    setpoint    = 5259, -- Airco Target Setpoint (gewenste temperatuur)
    operation   = 5257, -- Airco Operation Mode (welke HVAC functie, warmen, koelen etc)
    fan         = 5260, -- Airco Fan Mode (Ventilator snelheid)
    swingUD     = 5261, -- Airco Swing Mode Up/Down (blaasrichting omhoog/omlaag, auto)
    swingLR     = 5262, -- Airco Swing Mode Left/Right (optioneel, blaasrichting links/rechts, rechtdoor)
    aircoPower  = 5258  -- Airco Power (airco aan/uit schakelaar)
        devices = {
            IDX.temp,
            IDX.comfort
    execute = function(domoticz)
        local temp     = domoticz.devices(IDX.temp).temperature
        local comfort  = domoticz.devices(IDX.comfort).state
        local airco    = domoticz.devices(IDX.aircoPower)
        if comfort == 'Off' then
            domoticz.log('Airco Operation | Comfort UIT', domoticz.LOG_DEBUG)
            return
        local setpoint  = domoticz.devices(IDX.setpoint)
        local operation = domoticz.devices(IDX.operation)
        local fan       = domoticz.devices(IDX.fan)
        local swingUD   = domoticz.devices(IDX.swingUD)
        domoticz.log('Airco Operation | Temp=' .. temp, domoticz.LOG_INFO)
        -- VERWARMEN
        if temp < 16.5 then
            if airco.state == 'Off' then airco.switchOn() end
            setpoint.updateSetPoint(20)
            operation.setLevel(21) -- Heat
            fan.setLevel(30)
            swingUD.setLevel(30)
        elseif temp >= 16.5 and temp < 19.5 then
            operation.setLevel(20)
            fan.setLevel(20)
        -- COMFORTZONE → niets doen
        -- KOELEN
        elseif temp > 21.5 and temp <= 26.5 then
            setpoint.updateSetPoint(24)
            operation.setLevel(50) -- Cool
            fan.setLevel(50)
            swingUD.setLevel(60)
        elseif temp > 26.5 then
            setpoint.updateSetPoint(25)
            fan.setLevel(50)
-- Airco Eettafel – POWER CONTROL
-- Determines IF the airco is allowed to turn on
-- HOW the airco operates → see Airco Eettafel Operation Control script
-- Logic (priority high → low):
-- 1. Frost protection (always active)
-- 2. Comfort OFF → airco OFF
-- 3. If the temperature is within the comfort zone, the airco will not turn on
-- 4. Presence (at least one person present)
-- 5. God Mode (presence override)
-- Airco Eettafel - POWER CONTROL
-- Bepaalt OF de airco aan mag/gaat
-- HOE de airco werkt → zie Airco Eettafel Operation Control script
-- Logica (prioriteit hoog → laag):
-- 1. Vorstbeveiliging (altijd actief)
-- 2. Comfort UIT → airco UIT
-- 3. Als de temperatuur in de comfortzone zit, gaat de airco niet aan
-- 4. Presence (minstens 1 persoon aanwezig)
-- 5. God Mode (override presence)
-- CONFIGURATIE
local IDX = {
    -- metingen en bediening
    temp        = 3991,   -- Thermometer van de ruimte
    comfort     = 5268,   -- Airco Comfort schakelaar voor de ruimte
    aircoPower  = 5258,   -- Airco Power, aan/uit van de ruimte
    -- Presence, minimaal 1 van onderstaande moet thuis zijn
    -- PAS NAMEN AAN IN HET SCRIPT BIJ
        --return
        -- execute
    floris      = 5272,   -- Aanwezigheid Floris
    suzanne     = 5273,   -- Aanwezigheid Suzanne
    -- ben       = 5274,   -- ← makkelijk toe te voegen, voeg ook toe bij return en execute
    -- Override, ook al is er niemand thuis, Godmode aan, airco gaat aan indien nodig
    godmode     = 5286    -- God Mode
local MIN_TEMP   = 13.5   -- Vorstbeveiliging aan bij < 13.5
local HYSTERESIS = 1.0    -- Uit bij >= 14.5
local COMFORT_MIN = 19.5
local COMFORT_MAX = 21.5
-- SCRIPT
        devices = {
            IDX.temp,
            IDX.comfort,
            IDX.floris,
            IDX.suzanne,
            -- IDX.ben,
            IDX.godmode
        local floris   = domoticz.devices(IDX.floris).state == 'On'
        local suzanne  = domoticz.devices(IDX.suzanne).state == 'On'
        --         local ben  = domoticz.devices(IDX.ben).state == 'On'
        local godmode  = domoticz.devices(IDX.godmode).state == 'On'
        local someoneHome = floris or suzanne -- or ben
        domoticz.log(
            string.format(
                'Airco Power | Temp=%.1f | Comfort=%s | Home=%s | GodMode=%s | Airco=%s',
                temp,
                comfort,
                tostring(someoneHome),
                tostring(godmode),
                airco.state
            domoticz.LOG_DEBUG
        -- ❄️ Vorstbeveiliging (altijd prioriteit)
        if temp < MIN_TEMP then
                airco.switchOn()
                domoticz.log('Airco → ON (vorstbeveiliging)', domoticz.LOG_INFO)
            return
        elseif temp >= MIN_TEMP + HYSTERESIS and comfort == 'Off' then
            if airco.state == 'On' then
                airco.switchOff()
                domoticz.log('Airco → OFF (vorst voorbij, comfort uit)', domoticz.LOG_INFO)
            return
        -- Comfort UIT = airco UIT
                airco.switchOff()
                domoticz.log('Airco → OFF (comfort uit)', domoticz.LOG_INFO)
            return
-- Comfort AAN → check presence / God Mode
if not (someoneHome or godmode) then
        airco.switchOff()
        domoticz.log('Airco → OFF (niemand aanwezig)', domoticz.LOG_INFO)
    return
-- Comfortzone → airco mag UIT blijven
if temp >= COMFORT_MIN and temp <= COMFORT_MAX then
    domoticz.log('Airco Power | Comfortzone, airco blijft uit', domoticz.LOG_DEBUG)
    return
-- Buiten comfortzone → airco AAN
    airco.switchOn()
    domoticz.log('Airco → ON (buiten comfortzone)', domoticz.LOG_INFO)
Re: opzet voor comfort stand en schakelaar Mitsubishi Airco
Posted: Sunday 11 January 2026 15:25
Nice that you shared your project but this is an English written forum so please translate it to English!
