openScale
Posted: Wednesday 07 January 2026 11:12
by Varazir
Have anyone used openScale ?
It looks like this in the MQTT but nothing comes up in Domoticz.
and
Re: openScale
Posted: Wednesday 07 January 2026 11:21
Please post the complete config payload as text. There is a copy icon next to "Value" to copy it in MQTT Explorer
And I am not sure Domoticz supports device configs (with in it multiple components)
Re: openScale
Posted: Wednesday 07 January 2026 11:34
by Varazir
Not sure if it's going to be valid anymore as the app stoped working with the scale.
- Spoiler: show
"device": {
"name": "openScale",
"manufacturer": "olie.xdev",
"identifiers": "openscale"
"origin": {
"name": "openScale sync",
"sw_version": "0.4.4-oss",
"support_url": "https://github.com/oliexdev/openScale-sync"
"components": {
"openscale_weight": {
"name": "Weight",
"platform": "sensor",
"device_class": "weight",
"unit_of_measurement": "kg",
"value_template": "{{ value_json.weight | default(none) }}",
"unique_id": "openscale_weight"
"openscale_fat": {
"name": "Body fat",
"unit_of_measurement": "%",
"value_template": "{{ value_json.fat | default(none) }}",
"unique_id": "openscale_fat"
"openscale_muscle": {
"name": "Muscle",
"value_template": "{{ value_json.muscle | default(none) }}",
"unique_id": "openscale_muscle"
"openscale_water": {
"name": "Total body water",
"device_class": "moisture",
"value_template": "{{ value_json.water | default(none) }}",
"unique_id": "openscale_water"
"openscale_measurement_date": {
"name": "Measurement date",
"entity_category": "diagnostic",
"device_class": "timestamp",
"value_template": "{{ value_json.date | default(none) }}",
"unique_id": "openscale_date"
"openscale_measurement_id": {
"name": "Measurement id",
"value_template": "{{ value_json.id | default(none) }}",
"unique_id": "openscale_id"
"state_topic": "openScaleSync/measurements/last"
- Spoiler: show
"date": "2026-01-07T10:58+0100",
"fat": 0.0,
"id": 1,
"muscle": 0.0,
"water": 0.0,
"weight": 95.0
Re: openScale
Posted: Wednesday 07 January 2026 11:45
by Varazir
Maybe better buying a new scale. I would one that the RPi can read direct and translate to MQTT or custom use plugin.
Don't like to have an app that need to be running on my phone.
Re: openScale
Posted: Wednesday 07 January 2026 11:59
It looks like Domoticz does not support these kind of Config topics.
You could try to create a config topic manually with MQTT explorer for the scale.
The MQTT part is in the App or does the scale sends data to MQTT?
Re: openScale
Posted: Wednesday 07 January 2026 13:15
by Varazir
waltervl wrote: Wednesday 07 January 2026 11:59
You mean MQTT mapper ? I guess I could do that.
It's
https://play.google.com/store/apps/deta ... e.sync.oss app that syncs data from the main app.
I just read on the github for the app that there are a issue with just my scale.
https://github.com/oliexdev/openScale/issues/1246
Re: openScale
Posted: Wednesday 07 January 2026 13:27
Varazir wrote: Wednesday 07 January 2026 13:15
With MQTTMapper is also an option, but when you send With MQTT Explorer just a different (retained) MQTT config topic message that is compliant with Domoticz it will create the device(s).
https://www.home-assistant.io/integrati ... -discovery
Re: openScale
Posted: Wednesday 07 January 2026 17:46
by Varazir
waltervl wrote: Wednesday 07 January 2026 13:27
Never done that with MQTT Explorer
So as long as the device it create it will be able to read the values each time they are updated ?
Re: openScale
Posted: Wednesday 07 January 2026 18:59
Yes and when you send it as a retained MQTT message it will also be available when Domoticz restarts. You also have to delete the retained message from the MQTT server when you want to remove the device from Domoticz, else it will re-appear.
Re: openScale
Posted: Wednesday 07 January 2026 19:19
by Varazir
waltervl wrote: Wednesday 07 January 2026 18:59
Do you have an example?
Don't understand what to do
Re: openScale
Posted: Wednesday 07 January 2026 23:07
Sorry, the examples are in the home assitent llink I mentioned before. I do not use MQTT and even MQTT AD.
Re: openScale
Posted: Thursday 08 January 2026 10:46
by FlyingDomotic
If you wish to do that with MqttMapper, where's an example reading weight:
"Scale weight": {
"topic": "openScaleSync/measurements/last",
"type": 93, "subtype": 1,
"mapping": {"item": "weight"}
