High cpu load
elgringo
- Domoticz version: Left
High cpu load
I run a pi 5, with trixie, domoticz in a docker container, the latest stabel.
The cpu load is about 40%.
I was wondering what is better for the cpu load, trigger dzvents very minute or bij device updates, which most of the time are more than once a minute?
My gut feeling thinks it is caused by dzvents, but I don't know how to find the cause.
The thread with name: MainWorkerRxMsg is causing the high load. What does this thread do?
jannl
- Domoticz version: 2026.1.x
Re: High cpu load
40% seems high on a pi 5. On average on my pi 3b O se around 20% docker for Domoticz, Mosquitto and Zwave
- Domoticz version: 2026.3
Re: High cpu load
You can switch off dzvents/eventsystem completely through the Domoticz settings (tab other).
Or disable all the dzvents scripts manually through the event editor.
What also gives a high load is a P1 smart meter device that has a high update frequency (less than 10 seconds for updates) as it triggers a lot of devices and perhaps a lot of scripts, MQTT messages etc.
Tukker
- Domoticz version: 2023.2
Re: High cpu load
CPU Temperature....: 42.9'C
Load Averages......: 0.18, 0.08, 0.10
Disk Space.........: Free: 30G | Used: 26G 46%
Memory (RAM).......: Used: 556Mi | Free: 51Mi | Total: 906Mi
RPI3+ heavily in use.
Did you check with htop?
and try these
ps aux --sort=-%cpu | head -n 10
ps aux --sort=-%mem | head -n 10
For cpu and memory as sort factor respectively.
USER | %CPU | %MEM
root | 12.3 | 39.1 - /home/pi/domoticz/domoticz -daemon -www 8383 -sslwww 8443 -log /var/log/domoticz.log
root | 0.0 | 7.5 - /lib/systemd/systemd-journald
root | 0.0 | 3.9
and try these
USER | %CPU | %MEM
root | 0.0 | 3.9
Bugs bug me.
lost
Re: High cpu load
Also using a PI3B, but mostly in the 2/5% on cpu usage... And to limit heating the PI frequency is setup under max possible frequency so this should be even less.jannl wrote: Monday 05 January 2026 18:43 40% seems high on a pi 5. On average on my pi 3b O se around 20% docker for Domoticz, Mosquitto and Zwave
=> 20% for a PI3 is quite huge so let's not talk about 40% on a PI5!
Well, in my case a raspbian lite base, headless install (no DE/graphic support, only X11 frame-buffer to allow ssh in X11 forwarding mode for a few basic graphic tools that don't bring full-DE dependancies: terminal, using rxvt-unicode or editor, using nedit). No docker, but the PI managing several other services of my own (linked to domoticz) to handle IP cameras, BT presence detection...
The limitation of a PI3 is not the CPU, but the amount or RAM especially if using several tmpfs in order to minimize SD card wear.
elgringo
Re: High cpu load
My domoticz spikes sometimes at 17 ish %:
I also have a Hailo 8 in it which analyses frames of camera's, which takes about 8% cpu.
Most of the time the cpu is quite low (8%), but sometimes as high as 18%. I got a lot of switches and sensor on the floorplan, if the webpage is open does this have influence on the cpu load
all threads of domoticz:
root 1540 17.3 1.8 2501504 150992 ? Ssl 14:30 4:09 /opt/domoticz/domoticz -www 8080 -noupdates -sslwww 0 -userdata /opt/domoticz/userdata -log /tmp/log/domoticz/domoticz.logMost of the time the cpu is quite low (8%), but sometimes as high as 18%. I got a lot of switches and sensor on the floorplan, if the webpage is open does this have influence on the cpu load
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1865 root 20 0 2500480 150496 24368 S 6.2 1.8 1:22.15 MainWorkerRxMsg
1975 root 20 0 2500480 150496 24368 S 1.2 1.8 0:33.20 EventSystemQueu
1540 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.11 domoticz
1854 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.41 SQLHelper
1855 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.02 PluginMgr
1856 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.03 InfluxPush
1857 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.03 MQTTPush
1858 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.00 Webem_ssncleane
1859 root 20 0 2500480 150496 24368 S 0.0 1.8 0:09.27 WebServer_8080
1860 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.03 Scheduler
1861 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.00 TCPServer
1862 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.24 mDnsWorker
1863 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.00 domoticz
1864 root 20 0 2500480 150496 24368 S 0.0 1.8 0:01.54 MainWorker
1866 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.02 Watchdog
1875 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.02 WebServer_8080
1943 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.26 MainWorker
1944 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.07 Slimme Meter Ka
1945 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.38 Led
1946 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.41 TV
1947 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.07 Domoticz_HBWork
1948 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.03 KODI
1949 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.07 Domoticz_HBWork
1950 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.07 Domoticz_HBWork
1951 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.03 Pinger
1952 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.58 Zonnepanelen ov
1953 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.58 Zonnepanelen da
1954 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.42 Marantz
1957 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.08 Systeem
1958 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.82 KNMI
1959 root 20 0 2500480 150496 24368 S 0.0 1.8 0:01.26 RTL
1960 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.98 Zwave
1961 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.06 Domoticz_HBWork
1962 root 20 0 2500480 150496 24368 S 0.0 1.8 0:01.22 Zigbee
1963 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.07 Domoticz_HBWork
1964 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.83 MQTT
1965 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.07 Domoticz_HBWork
1966 root 20 0 2500480 150496 24368 S 0.0 1.8 0:05.86 Warmtepomp
1967 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.62 UPS
1968 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.56 Accu
1969 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.00 NotificationSys
1972 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.05 KodiNode
1974 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.04 EventSystem
1977 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.14 Plugin_ASIO
1980 root 20 0 2500480 150496 24368 S 0.0 1.8 0:00.00 RTL
Re: High cpu load
What version of Domoticz are you running? Stable 2025.2 or beta?
MainWorkerRxMsg seems to be the Incoming messages system, so there seems to be a high load somewhere.... What is the refresh rate setting of your smart meter?
elgringo
Re: High cpu load
Stable 2025.2waltervl wrote: Tuesday 06 January 2026 17:04 What version of Domoticz are you running? Stable 2025.2 or beta?
P1 meter updates every second. I need this for my home battery to control it. The control retrieve p1 meter values via json interface, every second a single call (read total usage and total delivery). No ideal but the control needs a much updates as possible. If I put the control loop in domoticz (a plugin) the load will become even more. Current it is standalone python code.
But this was also the case with my previous pi 4, and it had only a cpu load (total) of 8. So something has changed, but I cannot figure out what.
Is it possible to enable trace/debug logging to see what MainWorkerRxMsg is handling of messages?
zicht
- Domoticz version: 2023.1+
Re: High cpu load
Try to disable dzevents and see what happens.
If that is conclusive rename scripts so the dont run one by one, see what is causing it with dzevents on.
If that is not conclusive try disabling plugins one by one.
if still not found disable all & all scripts and see if its resolved --> if domoticz is the only thing that runs & still high cpu then you have a different problem
i have avg more then 80 devices / minute triggering the event system w/o cpu load problems.
maybe you have introduced some kind of a loop (meaning triggering itself continuesly)
Faulty plugin is less likely
- jvdz
- Domoticz version: 4.107
Re: High cpu load
One other thing you could check is the mqtt messages to/from domoticz to see which event messages are send/received by domoticz. Maybe there is some looping going on.
Re: High cpu load
You can switch on Domoticz debugging by changing the Docker environment parameter EXTRA_CMD_ARG with debug settingselgringo wrote: Thursday 08 January 2026 7:47 Is it possible to enable trace/debug logging to see what MainWorkerRxMsg is handling of messages?
https://wiki.domoticz.com/Docker#Debugging
I think you should at least add debuglevel "received"
