problem zwave2mqtt
Posted: Sunday 04 January 2026 23:07
this my docker compose yaml
I double checked correct 'ID' of zwave stick
it throws warnings causing noy usable :
Any help is appreciated.
Bart
zwave-js-ui | 2026-01-04 23:02:00.463 INFO APP: Version: 11.9.1.38aff57
zwave-js-ui | 2026-01-04 23:02:00.476 INFO APP: Application path:/usr/src/app
zwave-js-ui | 2026-01-04 23:02:00.477 INFO APP: Store path:/usr/src/app/store
zwave-js-ui | ______ __ __ _ _____ _ _ _____
zwave-js-ui | |___ / \ \ / / | |/ ____| | | | |_ _|
zwave-js-ui | / /____\ \ /\ / /_ ___ _____ | | (___ | | | | | |
zwave-js-ui | / /______\ \/ \/ / _' \ \ / / _ \ _ | |\___ \ | | | | | |
zwave-js-ui | / /__ \ /\ / (_| |\ V / __/ | |__| |____) | | |__| |_| |_
zwave-js-ui | /_____| \/ \/ \__,_| \_/ \___| \____/|_____/ \____/|_____|
zwave-js-ui |
zwave-js-ui | 2026-01-04 23:02:00.520 WARN STORE: scenes.json not found
zwave-js-ui | 2026-01-04 23:02:00.525 WARN STORE: nodes.json not found
zwave-js-ui | 2026-01-04 23:02:00.551 INFO APP: Listening on port 8091 protocol HTTP
zwave-js-ui | 2026-01-04 23:02:00.569 WARN BACKUP: Store backup is disabled
zwave-js-ui | 2026-01-04 23:02:00.571 WARN BACKUP: Nvm backup is disabled
zwave-js-ui | 2026-01-04 23:02:00.576 WARN Z-WAVE: Z-Wave driver not inited, no port configured
version: '3.7'
services:
zwave-js-ui:
container_name: zwave-js-ui
image: zwavejs/zwave-js-ui:latest
restart: always
tty: true
stop_signal: SIGINT
environment:
- SESSION_SECRET=mysupersecretkey
- ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db
# Change if you want log times and dates to match your timezone
# Available at https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
- TZ=Europe/Amsterdam
networks:
- zwave
devices:
# Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
# Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick.
- '/dev/serial/by-id/usb-0658_0200-if00:/dev/zwave'
volumes:
- zwave-config:/usr/src/app/store
# Or by using local folder
# - ./store:/usr/src/app/store
ports:
- '8091:8091' # port for web interface
- '3000:3000' # port for Z-Wave JS websocket server
networks:
zwave:
volumes:
zwave-config:
external: true
Bart
