Problem with Parameters from XML
Posted: Sunday 04 January 2026 14:11
hi All,
in my plugin I had build couple of parameters
.... and later in the code do the output of data to log:
Domoticz.Log("Plugin::onStart: Parameters: {}".format(repr(Parameters)))
and does not see my parameters line DzAddress, DzPort, MqttAddress, Mqttport, etc.
What I do wrong ?
BR
<params>
<!-- Domoticz API -->
<param field="DzAddress" label="Domoticz IP" width="200px" required="true" default="127.0.0.1"/>
<param field="DzPort" label="Domoticz Port" width="80px" required="true" default="8080"/>
<!-- MQTT Broker -->
<param field="MqttAddress" label="MQTT Server" width="200px" required="true" default="127.0.0.1"/>
<param field="MqttPort" label="MQTT Port" width="80px" required="true" default="1883"/>
<param field="MqttUsername" label="MQTT Username" width="200px" required="false"/>
<param field="MqttPassword" label="MQTT Password" width="200px" required="false" password="true"/>
What I do wrong ?
BR
