Timers API questions & remarks
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
jvdz
Domoticz version: 4.107
Post by jvdz »
I have been playing with the timers API's for both addtimer and addsetpointtimer and found some quirks and have some questions:
The "/json.htm?type=command&param=getschedules" only returns the timers that are none-persistent for both the switches and setpoint devices. Is this intentional?
eg: output for getschedules:
	"result" :
			"Active" : "true",
			"Color" : "",
			"Date" : "",
			"Days" : 1234567,
			"DevName" : "DeviceName",
			"DeviceRowID" : 57,
			"IsThermostat" : "false",
			"Level" : 40,
			"MDay" : 0,
			"Month" : 0,
			"Occurence" : 0,
			"Randomness" : "false",
			"ScheduleDate" : "2025-12-29 15:20:00",
			"Time" : "15:20",
			"TimerCmd" : 0,
			"TimerID" : 1,
			"TimerType" : 2,
			"TimerTypeStr" : "On Time",
			"Type" : "Device"
			"Active" : "true",
			"Date" : "",
			"Days" : 1234567,
			"DevName" : "Devicename3",
			"DeviceRowID" : 59,
			"IsThermostat" : "true",
			"MDay" : 0,
			"Month" : 0,
			"Occurence" : 0,
			"ScheduleDate" : "2025-12-29 15:05:00",
			"Temperature" : "15.6",
			"Time" : "15:05",
			"TimerID" : 2,
			"TimerType" : 2,
			"Type" : "Device"
	"status" : "OK",
	"title" : "getschedules"
the "/json.htm?type=command&param=gettimers&idx=57" does return them all:
	"result" :
			"Active" : "true",
			"Cmd" : 0,
			"Color" : "",
			"Date" : "",
			"Days" : 1234567,
			"Level" : 40,
			"MDay" : 0,
			"Month" : 0,
			"Occurence" : 0,
			"Persistent" : "false",
			"Time" : "15:20",
			"Type" : 2,
			"idx" : "1"
			"Active" : "true",
			"Cmd" : 0,
			"Color" : "",
			"Date" : "",
			"Days" : 127,
			"Level" : 100,
			"MDay" : 0,
			"Month" : 0,
			"Occurence" : 0,
			"Persistent" : "true",
			"Randomness" : "true",
			"Time" : "11:05",
			"Type" : 2,
			"idx" : "2"
			"Active" : "true",
			"Cmd" : 0,
			"Color" : "",
			"Date" : "",
			"Days" : 134,
			"Level" : 100,
			"MDay" : 0,
			"Month" : 0,
			"Occurence" : 0,
			"Time" : "11:10",
			"Type" : 2,
			"idx" : "3"
			"Active" : "true",
			"Cmd" : 0,
			"Color" : "",
			"Date" : "",
			"Days" : 13,
			"Level" : 100,
			"MDay" : 0,
			"Month" : 0,
			"Occurence" : 0,
			"Time" : "11:16",
			"Type" : 2,
			"idx" : "4"
	"status" : "OK",
	"title" : "gettimers"
Maybe I am not properly understanding what persistent really means, other than that one can't override them, but I did expect the "/json.htm?type=command&param=getschedules" to return them all!?
Some Wiki remarks:
"/json.htm?type=command&param=addtimer&idx=DeviceRowID&active=true&timertype=2&hour=0&min=20&randomness=false&command=0&days=1234567"
- is missing the persistent option
- states that "days = 1=Mon, 2=Tue, 3=Wed, 4=Thurs, 5=Fri, 6=Sat, 7=Sun", but that should be:
	-- days bit position: 1=mon (1), 2=tue (2), 3=wed (4), 4=thu (8), 5=fri (16), 6=sat (32), 7=sun (64).
	     Add the values in the brackets together for the days to be activated.  eg 40=thu+sat
	-- 128 = all days
	-- 256 = weekdays
	-- 512 = weekends
The addsetpointtimer/updatesetpointtimer/deletesetpointtimer api's aren't documented in the wiki yet:
/json.htm?type=command&param=addsetpointtimer&idx=IDX&active=true&timertype=2&hour=12&min=0&persistent=false&tvalue=15&vunit=%C2%B0C&days=1234567
/json.htm?type=command&param=updatesetpointtimer&idx=Timer_Id&active=true&timertype=2&hour=12&min=0&persistent=false&tvalue=15&vunit=%C2%B0C&days=1234567
will add stuff when i encounter more stuff.
Re: Timers API questions & remarks
Persistent: Will be available in all timer plans when enabled. (available from beta dd 20-12-2023) ( https://wiki.domoticz.com/Managing_Devi ... ice_Timers )
I suppose that is why persistent are not listed with getschedules. Where is this API call used in the gui?
You are free to update the wiki when needed ;-)
jvdz
Post by jvdz »
waltervl wrote: Monday 29 December 2025 13:02 Persistent: Will be available in all timer plans when enabled. (available from beta dd 20-12-2023)
I've seen that but it simply isn't clear in my mind yet what that means. So what exactly is the difference between a persistent and non persistent timer as far as behaviour?
waltervl wrote: Monday 29 December 2025 13:02 I suppose that is why persistent are not listed with getschedules. Where is this API call used in the gui?
I don't suppose anything when coding in general and am looking for logic answers when having my coderbrain switched on. 😉
waltervl wrote: Monday 29 December 2025 13:02 You are free to update the wiki when needed ;-)
Understood, but I only document stuff I understand.
jvdz
Post by jvdz »
To answer the question why they are not in getschedules, i looked in the sourcecode and it is because TimerPlan==9999 aren't selected:
this is in the sql WHERE statement for getschedules:
"SELECT t.ID, t.Active, d.[Name], t.DeviceRowID AS ID, 0 AS IsScene, 0 AS IsThermostat, t.[Date], t.Time, t.Type, t.Cmd, t.Level, t.Color, 0 AS Temperature, t.Days, t.UseRandomness, t.MDay, t.Month, t.Occurence"
" FROM Timers AS t, DeviceStatus AS d"
" WHERE (d.ID == t.DeviceRowID) AND (t.TimerPlan==%d)"
" ORDER BY d.[Name], t.Time"
missing TimerPlan  in Select and no field "persistent" is created for the result.
and this for gettimers:
("SELECT ID, Active, [Date], Time, Type, Cmd, Level, Color, Days, UseRandomness, MDay, Month, Occurence, TimerPlan"
" FROM Timers "
" WHERE (DeviceRowID==%" PRIu64 ") AND ((TimerPlan==%d) OR (TimerPlan==9999))"
" ORDER BY ID"
.... result field definition...
root["result"][ii]["Persistent"] = (atoi(sd[13].c_str()) == 9999) ? "true" : "false";
So question remains whether this is deliberate or a missed update when persistent was introduced. :-)
There is only one to ask ;-)
But where in the gui is getschedules used? I do not think it is used somewhere. So probably the reason it was not changed during introduction of the persistent timers as it has no influence on the gui of Domoticz.
JanJaap
Domoticz version: Dev
Post by JanJaap »
Hey,
I'm getting the same result (all timers) on "/json.htm?type=command&param=getschedules"
but the other command "/json.htm?type=command&param=gettimers&idx=545" (both with idx for switch and setpoint devices) returns just this:
	"status" : "OK",
not sure still how to make a timer persistent. As far as I understand the term 'persistent', all timers are?
btw, updatesetpointtimer works fine with the given params
