include my own pythons plugin in the domoticz
Posted: Monday 29 December 2025 0:34
by svd71
Hi all.
I have old Paspberry pi 3B with 1G on the board, Bullseye, and Domoticz Version: 2024.7.
I did installed couple of plugins: SamsungTV, Mikrotik, RPi, tasmota-auto.
But I have problem with my own plugin. I had checked all:
permissions, owner, start in console with python (run without errors).
After restart of domoticz-service does not see any information in the log about plugins-initialization process.
I have did a mistake in the plugins code and restart the service again - no error messages.
can somebody explain me what I did wrong?
BR.
Re: include my own pythons plugin in the domoticz
Posted: Monday 29 December 2025 9:24
Did you add it as a hardware gateway?
Posted: Monday 29 December 2025 10:05
by madpatrick
Can you share the plugin then we can test if it works with others systems
Posted: Monday 29 December 2025 12:41
by svd71
@madpatrick : The plugin is hier in spoiler:
- Spoiler: show
<plugin
key="TasmotaMQTTIntegration"
name="Tasmota MQTT Integration"
author="S.Pfaffenrot"
version="1.0.0"
externallink="https://tasmota.github.io/docs/">
<description>
Tasmota MQTT Integration Plugin<br/>
This plugin listens to MQTT messages from Tasmota devices and updates corresponding Domoticz switches based on JSON in their descriptions.
</description>
<params>
<param field="Address" label="MQTT Server" width="200px" required="true" default="localhost"/>
<param field="Port" label="MQTT Port" width="40px" required="true" default="1883"/>
<param field="Username" label="MQTT Username" width="200px" required="false"/>
<param field="Password" label="MQTT Password" width="200px" required="false" password="true"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
aaaaaaaa
errmsg = ""
try:
import Domoticz
except Exception as e:
errmsg += "tas:Domoticz core start error: "+str(e)
try:
import json
errmsg += "tas: json: "+str(e)
try:
import paho.mqtt.client as mqtt
errmsg += "tas: mqtt::MqttClient import error: "+str(e)
class BasePlugin:
def __init__(self):
self.mqttClient = None
self.mqttConnected = False
self.debug = False
def onStart(self):
if Parameters["Mode6"] == "Debug":
self.debug = True
Domoticz.Debugging(1)
else:
Domoticz.Debugging(0)
Domoticz.Log("tas: plugin starting...")
# Create MQTT client
self.mqttClient = mqtt.Client()
self.mqttClient.on_connect = self.onMQTTConnect
self.mqttClient.on_disconnect = self.onMQTTDisconnect
self.mqttClient.on_message = self.onMQTTMessage
if Parameters["Username"] != "":
self.mqttClient.username_pw_set(Parameters["Username"], Parameters["Password"])
# Connect to MQTT
try:
self.mqttClient.connect(Parameters["Address"], int(Parameters["Port"]), 60)
self.mqttClient.loop_start()
Domoticz.Error("tas: MQTT connection error: " + str(e))
def onStop(self):
Domoticz.Log("tas: Plugin stopping...")
if self.mqttClient is not None:
self.mqttClient.loop_stop()
self.mqttClient.disconnect()
def onMQTTConnect(self, client, userdata, flags, rc):
if rc == 0:
self.mqttConnected = True
Domoticz.Log("tas: Connected to MQTT broker with result code " + str(rc))
# Subscribe to relevant topics
self.mqttClient.subscribe("tele/#")
self.mqttClient.subscribe("stat/#")
else:
Domoticz.Error("tas: Failed to connect to MQTT, return code: " + str(rc))
def onMQTTDisconnect(self, client, userdata, rc):
Domoticz.Log("tas: Disconnected from MQTT broker with result code " + str(rc))
def onMQTTMessage(self, client, userdata, msg):
try:
topic = msg.topic
payload = msg.payload.decode("utf-8")
if self.debug:
Domoticz.Debug("tas: MQTT Message: Topic=" + topic + ", Payload=" + payload)
# Parse topic to extract device topic (e.g., tasmota_94F93D)
topic_parts = topic.split('/')
if len(topic_parts) < 2:
return
device_topic = topic_parts[1] # e.g., tasmota_94F93D
# Parse JSON payload
payload_json = json.loads(payload)
# Case 1: tele/.../SENSOR = {"Time":..., "Switch3":"OFF"}
if topic.startswith("tele/") and "SENSOR" in topic_parts:
for key, value in payload_json.items():
if key.startswith("Switch") and value in ["ON", "OFF"]:
switch_name = key # e.g., Switch3
new_state = value # ON or OFF
self.updateDomoticzDevice(device_topic, switch_name, new_state)
# Case 2: stat/.../RESULT = {"Switch3":{"Action":"TOGGLE"}}
elif topic.startswith("stat/") and "RESULT" in topic_parts:
if key.startswith("Switch") and isinstance(value, dict) and "Action" in value and value["Action"] == "TOGGLE":
self.toggleDomoticzDevice(device_topic, switch_name)
Domoticz.Error("tas: Error processing MQTT message: " + str(e))
def updateDomoticzDevice(self, device_topic, switch_name, new_state):
# Find Domoticz device with matching JSON in Description
found = False
for dev_id, device in Devices.items():
try:
desc_json = json.loads(device.Description)
if isinstance(desc_json, dict) and \
"Topic" in desc_json and desc_json["Topic"] == f"cmnd/{device_topic}" and \
"Device" in desc_json and desc_json["Device"] == switch_name:
found = True
# Update status: ON -> 1 (or 100 for level), OFF -> 0
nvalue = 1 if new_state == "ON" else 0
svalue = "100" if new_state == "ON" else "0" # For selector or dimmer, adjust if needed
device.Update(nValue=nvalue, sValue=svalue)
Domoticz.Log(f"tas: Updated device {dev_id} ({device.Name}) to {new_state}")
break
except json.JSONDecodeError:
pass # Invalid JSON in description, skip
if not found:
Domoticz.Log(f"tas: No matching Domoticz device found for {device_topic}/{switch_name}")
def toggleDomoticzDevice(self, device_topic, switch_name):
# Find Domoticz device and toggle it
found = False
try:
found = True
# Toggle: if currently ON (nValue=1), set to OFF, and vice versa
new_nvalue = 0 if device.nValue == 1 else 1
new_svalue = "0" if new_nvalue == 0 else "100"
device.Update(nValue=new_nvalue, sValue=new_svalue)
new_state = "ON" if new_nvalue == 1 else "OFF"
Domoticz.Log(f"tas: Toggled device {dev_id} ({device.Name}) to {new_state}")
break
pass
if not found:
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
pass
def onMessage(Connection, Data):
pass
def onCommand(Unit, Command, Level, Color):
pass
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
pass
def onDisconnect(Connection):
pass
def onHeartbeat():
pass
@walterw: what is it a "hardware gateway" and how need to add to the domoticz? Send please me a link to description of process if it present.
Posted: Monday 29 December 2025 13:14
svd71 wrote: Monday 29 December 2025 12:41
That is in menu Setup-Hardware
See wiki for installing a plugin
https://wiki.domoticz.com/Using_Python_ ... g_a_plugin
By the way, there is already a MQTT Tasmoticz plugin available:
viewtopic.php?t=21918
Posted: Monday 29 December 2025 13:15
by svd71
thank you very much!
I have it. But it is same question, why I did not see it in the menu "Hardware" for settings.
Posted: Monday 29 December 2025 13:39
You first have to add it in the form below this list:
https://wiki.domoticz.com/Hardware_Setu ... re_Gateway
Posted: Monday 29 December 2025 13:54
by svd71
Thank you very much!
I had found it !!!
