[2025-2] log display speed
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
knasson
Domoticz version: 2026-3
Post by knasson »
the display of the domoticz log is very quick and i am unable to read it.
Is it possible to slow down this display?
thank you
Re: [2025-2] log display speed
It comes in as it goes by. You can scroll back/up..
You can filter the log on a device name or hardware name in the search field top right.
You can also disable the info log on the hardware you are not interested in.
Or bring the log into a file when you have enough disk space. Then you can read back easily.
jannl
Domoticz version: 2026.1.x
Post by jannl »
On Linux you can send it to a logserver (ie synology nas) and check it there.
Disable the logging of hardware that runs fine to minimize the logging.
