Domoticz docker under Wireguard
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
acaonweb
Post by acaonweb »
hi, recently I've discovered an issue.
i've wireguard server for my lan, and I can access to my lan from remote, I can reach zigbee server, portainer server, node red server, etc
but not my domoticz server
domoticz is into a container
it's the only server I can't reach.
i suppose that is something related to domoticz container, but I cant find a way to resolve it
I attach domoticz and wg-easy stacks compose.
Domoticz info
Version: 2025.2 (build 16818)
Build Hash: 2f9016a8b
Compile Date: 2025-10-19 11:41:46
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0]
Active User: pi
Thanx for any suggestion and help
Fabrizio
domoticz stack
version: '3.8'
services:
  domoticz:
    image: domoticz/domoticz:stable
    container_name: domoticz
    restart: unless-stopped
    depends_on:
      - mosquitto
    networks:
      myNetwork:
        ipv4_address: ---.---.---.153
    ports:
      - "8080:8080"
    volumes:
      - /srv/dev-disk-by-uuid-36662cd8-800d-4017-83bc-40f63d06148e/domoticz:/opt/domoticz/userdata
  mosquitto:
    image: eclipse-mosquitto
    container_name: mosquitto
    restart: always
    volumes:
      - /srv/dev-disk-by-uuid-36662cd8-800d-4017-83bc-40f63d06148e/mqtt/config:/mosquitto/config
      - /srv/dev-disk-by-uuid-36662cd8-800d-4017-83bc-40f63d06148e/mqtt/data:/mosquitto/data
      - /srv/dev-disk-by-uuid-36662cd8-800d-4017-83bc-40f63d06148e/mqtt/log:/mosquitto/log
    networks:
      myNetwork:
        ipv4_address: ---.---.---,160
    ports:
      - 1883:1883
      - 9001:9001
    stdin_open: true
    tty: true
  homebridge:
    image: homebridge/homebridge:ubuntu
    container_name: homebridge-dz
    restart: always
    depends_on:
      - domoticz
    # network_mode: host
    networks:
      myNetwork:
        ipv4_address: ---.---.---.142 #add ip here
    ports:
      - "1968:1968"
    environment:
      - HOMEBRIDGE_CONFIG_UI_PORT=1968
    volumes:
      - /srv/dev-disk-by-uuid-83b6a8f9-5b92-4b9f-ab73-81c3cf7cc424/homebridge:/homebridge
networks:
  myNetwork:
    external: true
wg-easy
volumes:
  etc_wireguard:
services:
  wg-easy:
    environment:
      # Change Language:
      # (Supports: en, ua, ru, tr, no, pl, fr, de, ca, es, ko, vi, nl, is, pt, chs, cht, it, th, hi)
      - LANG=it
      # ⚠️ Required:
      # Change this to your host's public address
      - WG_HOST=---.---.----.168
      # Optional:
      - PASSWORD_HASH=$-------------------------------------------------------------------------------------------------- see "How_to_generate_an_bcrypt_hash.md" for generate the hash)
      - PORT=51821
      - WG_PORT=51821
      # - WG_CONFIG_PORT=92820
      # - WG_DEFAULT_ADDRESS=10.8.0.x
      # - WG_DEFAULT_DNS=1.1.1.1
      # - WG_MTU=1420
      - WG_ALLOWED_IPS=---.---.---.0/24
      # - WG_PERSISTENT_KEEPALIVE=25
      # - WG_PRE_UP=echo "Pre Up" > /etc/wireguard/pre-up.txt
      # - WG_POST_UP=echo "Post Up" > /etc/wireguard/post-up.txt
      # - WG_PRE_DOWN=echo "Pre Down" > /etc/wireguard/pre-down.txt
      # - WG_POST_DOWN=echo "Post Down" > /etc/wireguard/post-down.txt
      # - UI_TRAFFIC_STATS=true
      # - UI_CHART_TYPE=0 # (0 Charts disabled, 1 # Line chart, 2 # Area chart, 3 # Bar chart)
      # - UI_SHOW_LINKS=true
      # - UI_ENABLE_SORT_CLIENTS=true
    image: ghcr.io/wg-easy/wg-easy
    container_name: wg-easy
    volumes:
      - etc_wireguard:/etc/wireguard
    ports:
      - "51821:51821/udp"
      - "51821:51821/tcp"
    cap_add:
      - NET_ADMIN
      - SYS_MODULE
      # - NET_RAW # ⚠️ Uncomment if using Podman
    sysctls:
      - net.ipv4.ip_forward=1
      - net.ipv4.conf.all.src_valid_mark=1
gizmocuz
Re: Domoticz docker under Wireguard
Post by gizmocuz »
You did not discovered an issue, you have an issue
Using domoticz via wireguard for many years without issue.
You should not need to give each container a fixed IP address, your machine probably already has a fixed address that you configured in your router
Do you need a external network?
acaonweb
Post by acaonweb »
ok, maybe only me have this issue, but:
1) consider that I have a lot of docker stacks with their external IP that works great under VPN (domoticz is the only one)
2) my docker host IP has 8080 port not available
3) changing the domoticz port force me to change more than 20 scripts/nodered/python
4) I like to have organized in this way my servers
I can reach my docker frontend with a cloudflare tunnel, but VPN is a good "plan b" when cloud flare isn't ON
Have you some suggestion?
Thanx in advance
Fabrizio
jannl
Domoticz version: 2026.1.x
Post by jannl »
Same here works great, like gizmocuz says.
Wireguard VPN on my fritzbox, pi has a fix IP, docker just runs. I added my whole internal subnet to Domoticz and because the VPN range is in that, never had a problem with that. Even with other VPN's like OpenVPN and and ipsec tunnel.
acaonweb
Post by acaonweb »
but you don't have an macvlan network in docker make domoticz container expose its own IP address, right?
jannl
Post by jannl »
acaonweb wrote: Wednesday 24 December 2025 12:57 but you don't have an macvlan network in docker make domoticz container expose its own IP address, right?
Nope.
I read a docker-host can not standard communicate with a macvlan without additional settings. KISS is my way to go.
