Zigbee Aut Discover + AduroSmart Dimmer Plug
Posted: Wednesday 10 December 2025 22:58
My setup:
Device was added OK to Zigbee2Mqtt.
I see the device when I browse Mqtt Explorer. Device is also added under the AutoDiscovery topic.
When I enable the AutoDiscovery plugin in Domoticz, all Zigbee devices are discovered.
But the AduroSmart is only partially discovered (i.e. not all devices)).
Only Topic <AutoDiscoveryPrefix>/<select>/<devicename>/Effect is discovered by Domoticz.
The <AutoDiscoveryPrefix>/<light>/<devicename>/light is not discovered! And you need that one to turn the plug on/off or dim it.
Also <AutoDiscoveryPrefix>/<select>/<devicename>/power_on_behaviour is present, but not discovered. I have no idea if that one needs to be discovered.
But, when I change the name of the device in Zigbee2Mqtt the <AutoDiscoveryPrefix>/<light>/<devicename>/light is discovered by Domoticz.
So that seems to be Ok, until you reboot the system or turn off/ on the Mqtt Auto Discovery plugin. Then the device belonging to topic <devicename>/light isn't discovered (if a device was discovered after renaming the device in zigbee2mqtt it can't be used). Change the name in Zigbee2Mqtt and its discovered again; and the device can be used again.
My setup:
- Domoticz: 2025.2
- Zigbee2Mqtt
- Several Zigbee devices
