Meteorologisk institutt Norway (Weather Lookup) not
Posted: Sunday 30 November 2025 19:12
by rini52
Meteorologisk institutt Norway (Weather Lookup) gives error :>
"2025-11-30 18:58:59.124 Error: Weather_home: Error getting http data!. "
Deleting the hardware and re-adding gives similar error result. Also all related devices were removed.
It worked until I did a restart of the docker container.
Any idea how to get it working again?
Re: Meteorologisk institutt Norway (Weather Lookup) not
Posted: Monday 01 December 2025 0:10
Did it work before? If so, what has changed in your setup?
If not, did you fill in the location in menu Setup, Settings?
Posted: Monday 01 December 2025 8:32
by rini52
It worked before. I did fill in the lat/lon in de the setup no result. I probably did a rebuild of the container via a stack in portainer (iam not sure anymore). I did also try to setup a pp-manager also that failed with an error in the log file. Checked the plugin directory on read/write was (rwx) so also no restiction.
it wroked under the new 2025.2 (stable) untill a couple of days before. It runs on a p1 4 as a docker container . Pi4 still on previuos bullseye release but did an apt update. Difficult to get a grip on it so far.
Posted: Monday 01 December 2025 9:21
What happens if you run the following http call from the server? You can change lat and lon to real values.
curl https://api.met.no/weatherapi/locationforecast/2.0/complete.json?lat=5&lon=51
Posted: Monday 01 December 2025 9:51
by rini52
Hi Walter,
Found the solution. Apparently the portainer version was not up to date. Did apt- upgrade, portainer update, restarted docker-ce . After that no http errors and the (weather)devices were added again and hopefully they will be updated with data. I assume, what happened was that domoticz was not properly started/rebuild because of wrong portainer version/stack. Strange all my other containers (ie.. mqqt, z2m,vcode etc) worked ok.
Anyway lesson learned. If it isn't broken leave it...
