TTN to Domoticz without CayenneLPP
Posted: Monday 24 November 2025 13:42
i am new to this subject and after trying for 2 days now, i think asking for help is the only way for me to get this running.
I have a device sending with lorawan to ttn. TTN send mqtt/ i am trying to pic them up on their server.
In Domoticz i installed new hardware: MQTT Client Gateway with Lan Interface- Remote adress is eu1.cloud.thethings.network, Port ist 1883, Username is x@ttn, password ist API key. Topic in prefix is: v3/x@ttn/devices
with this datamqtt explorer shows my decoded payload.
End device in TTN uses "Use Device Repository formatter"
MQTT Explorer shows:
domoticz log just shows:
then i do have a lua script supposed to translate the paylode to idx's
So why is ther no Payload coming in to Domoticz? If it did come in, does the script run properly?
function decodeUplink(input) {
switch (input.fPort) {
case 10:
bytes = input.bytes;
var data = {};
for (i=0 ; i<bytes.length; i++) {
switch (bytes[i]) {
case 0x03:
data.hw_version = bytes[++i];
data.capabilities = (bytes[++i] << 8)+ bytes[++i];
break;
case 0x04:
p = bytes[++i];
v = (bytes[++i] << 8)+ bytes[++i];
switch (p) {
case 0x01:
data.conf_system=v;
break;
case 0x02:
data.conf_heartbeat=v;
break;
case 0x03:
data.conf_heavyrain=v;
break;
case 0x04:
data.conf_interval=v;
break;
default:
if (p > 16) data.error = "config parameter? "+bytes[i];
else {
data.conf_parameter = p;
data.conf_value = v;
break;
case 0x06:
sensor = bytes[++i];
sensorvalue = (bytes[++i] << 8)+ bytes[++i];
switch(sensor) {
case 0x01:
if (sensorvalue < 0x4000)
data.temperature_C = sensorvalue/10.0;
data.temperature_C = (sensorvalue - 0xffff)/10.0;
break;
case 0x02:
data.humidity = sensorvalue;
break;
case 0x03:
data.uptime = sensorvalue;
break;
case 0x08:
data.airtemperature_C = sensorvalue/10.0;
data.airtemperature_C = (sensorvalue - 0xffff)/10.0;
break;
case 0x11:
data.consumption = sensorvalue;
break;
case 0x12:
data.flow = sensorvalue;
break;
case 0x81:
data.rainlevel = sensorvalue * 0.5 ; // 1 == 500 ml
break;
default:
data.error = "sensor type? "+bytes[i];
break;
case 0x07:
data.motorposition = bytes[++i];
break;
case 0x0a:
data.fw_version = (bytes[++i] << 24) +(bytes[++i] << 16) + (bytes[++i] << 8) + bytes[++i];
break;
case 0x0b:
data.a_status = bytes[++i];
data.a_type = bytes[++i];
data.a_value = (bytes[++i] << 8)+ bytes[++i];
var val;
switch (data.a_type) {
case 0x01:
data.alarm = "Flood";
val = " ";
break;
case 0x02:
data.alarm = "Temperature Low";
if (data.a_value > 0x4000)
data.a_value = (data.a_value - 0xffff)/10.0;
val = " with " + data.a_value + " C";
break;
case 0x03:
data.alarm = "Heavyrain";
val = " with " + data.a_value + " l/m3";
break;
case 0x04:
data.alarm = "Humidity";
val = " with " + data.a_value + " %";
break;
case 0x05:
data.alarm = "Vibration";
val = " device";
break;
case 0x06:
data.alarm = "Temperature High";
break;
case 0x07:
data.alarm = "Air Temperature Low";
break;
case 0x0c:
data.alarm = "Battery";
val = " with " + data.a_value + " mAh";
break;
default:
data.error = "Alarm? "+data.a_type;
break;
if (data.a_status) data.alarm += " on" + val; else data.alarm += " off" + val;
break;
case 0x12:
data.bat_volt = (bytes[++i])/10.0;
data.bat_mAh = (bytes[++i] << 8) + bytes[++i];
break;
case 0x33:
data.duration = (bytes[++i] << 8)+ bytes[++i];
data.diff = (bytes[++i] << 8)+ bytes[++i];
break;
default:
data.error = "command? "+bytes[i];
return { data: data};
default:
return {errors: ['invalid FPort']};
function encodeDownlink(input) {
cmd = input.data.cmd;
switch (String(cmd)) {
case "config_set":
fPort: 10,
bytes: [0x04, input.data.parameter, (input.data.value>>8) & 0xff, input.data.value & 0xff],
case "get_hw":
fPort: 10,
bytes: [0x03],
case "get_fw":
fPort: 10,
bytes: [0x1a],
case "config_get":
fPort: 10,
bytes: [0x14, input.data.parameter],
function decodeDownlink(input) {
data = {};
if (input.fPort != 10)
errors: ['invalid FPort'],
switch (bytes[0]) {
case 0x04:
data.cmd = "config_set";
data.parameter = bytes[1];
data.value = (bytes[2] << 8)+ bytes[3];
break;
case 0x03:
data.cmd = "get_hw";
break;
case 0x0a:
data.cmd = "get_fw";
break;
case 0x04:
data.cmd = "config_get";
break;
return {data:data}
}Code: Select all
"end_device_ids": {
"device_id":"y","application_ids" {
"application_id":"x"
"dev_eui":"060000F6xxx","join_eui":"49434854xxx1","dev_addr":"260B8xx"},
"correlation_ids":["gs:uplink:01KATNGAEXDXZKQ5Q9QJ5HTV3C"],
"received_at":"2025-11-24T10:10:45.547949795Z",
"uplink_message":{
"session_key_id":"AZqYkxmTl646rq5ll3XJlQ==",
"f_port":10,"f_cnt":95,"frm_payload":"Eh0AAwYBAPoGgQAA",
"decoded_payload":{
"bat_mAh":3,
"bat_volt":2.9,
"rainlevel":0,
"temperature_C":25},
"rx_metadata":[{
"gateway_ids":{
"gateway_id":"eui-7076ff005607xx","eui":"7076FF005xx"},
"time":"2025-11-24T10:10:45.263Z",
"timestamp":3943593060,"rssi":-122,
"channel_rssi":-122,
"snr":-1.2,
"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwNzBiODxx/wBWBwuDEOxxxgwIpd6QyQYQjNDPogEgoM3ag+OFTioLCKXekMkGEMCftH0=",
"channel_index":5,
"gps_time":"2025-11-24T10:10:45.263Z",
"received_at":"2025-11-24T10:10:45.341043212Z"}],
"settings":{
"data_rate":{
"lora":{
"bandwidth":125000,
"spreading_factor":10, "coding_rate":"4/5"}},
"frequency":"868100000", "timestamp":3943593060, "time":"2025-11-24T10:10:45.263Z"},"received_at":"2025-11-24T10:10:45.342156701Z","consumed_airtime":"0.411648s",
"packet_error_rate":0.071428575,
"locations":{"user":{"latitude":53.xxx,"longitude":9.xxx,"altitude":22,"source":"SOURCE_REGISTRY"}},
"version_ids":{"brand_id":"aquascope", "model_id":
"ran",
"hardware_version":"1.0",
"firmware_version":"241115",
"band_id":"EU_863_870"},"network_ids":{"net_id":"000013",
"ns_id":"EC656E0000000181",
"tenant_id":"ttn","cluster_id":"eu1",
"cluster_address":"eu1.cloud.thethings.network"}}}Code: Select all
TtnMqttFuerLuaScripte: Connected to: eu1.cloud.thethings.network:1883Code: Select all
-- Lua script to parse TTN MQTT messages
-- Das VOLLSTÄNDIGE erwartete MQTT Topic
-- Dies ist der exakte Topic-String, den TTN verwendet
local expectedFullTopic = "v3/x@ttn/devices/y/up" --DAS MUSS FÜR JEDES DEVICE UND GGF AUCH FÜR DIE APPLICANTION NEU
local rainSensorIDX = 45
local batSensorIDX = 46
-- PRÜFUNG HINZUFÜGEN: Stellen Sie sicher, dass 'devicechanged' existiert und 'MQTTTopic' enthält
if (devicechanged and devicechanged['MQTTTopic']) then
-- Prüfen, ob es der RICHTIGE, vollständige Topic ist
if (devicechanged['MQTTTopic'] == expectedFullTopic) then
-- Die JSON-Payload auslesen
local jsonPayload = devicechanged['MQTTPayload']
-- JSON dekodieren
local decodedData = jsonlite.decode(jsonPayload)
-- Überprüfen, ob die Dekodierung erfolgreich war und die Datenstruktur passt
if (decodedData and decodedData.uplink_message and decodedData.uplink_message.decoded_payload) then
-- Hier greifen Sie auf die spezifischen Werte zu, die TTN dekodiert hat
local rainlevel = decodedData.uplink_message.decoded_payload.rainlevel
local bat_volt = decodedData.uplink_message.decoded_payload.bat_volt
-- Werte in die virtuellen Domoticz-Geräte schreiben
if (rainlevel) then
commandArray = {['UpdateDevice'] = rainSensorIDX .. "|0|" .. rainlevel}
if (bat_volt) then
commandArray = {['UpdateDevice'] = batSensorIDX .. "|0|" .. bat_volt .. ";0"}
return commandArraySo why is ther no Payload coming in to Domoticz? If it did come in, does the script run properly?
