MQTT broker question
Posted: Friday 21 November 2025 13:59
by Herman-H
I'm a noob, a question: is it possible to use Homey's MQTT broker in Domoticz instead of local host in MQTT Client Gateway with LAN interface?
Re: MQTT broker question
Posted: Friday 21 November 2025 14:11
by jvdz
Mosquitto is an MQTT-Broker, which you could call the server that acts as an store-and-forward of the MQTT packages send/received bij the clients.
Domoticz and Homey are clients the Send/receive MQTT messages.
So when your question is: Can I use a MQTT-Broker running on another server with the Domoticz client then the answer is: Yes you can, simply supply the correct ip address of the target server.
Posted: Friday 21 November 2025 16:23
You can also install a MQTT broker or Server (the new term) on Homey. https://homey.app/nl-nl/app/net.weejewe ... TT-Server/
If you installed that you can use that Homey MQTT Server/broker as the MQTT server in your network, also for Domoticz to publish to and subscribe on.
Posted: Friday 21 November 2025 19:54
by Herman-H
Thanks jvdzand waltervl, its working
