mismatch with zigbee2mqtt (payload zigbee thermostate) and domoticz
Posted: Thursday 20 November 2025 10:23
I use a Tuya ZWT198/ZWT100-BH thermostate and for zigbee it uses TS0601 model
I want to use the value running_state' to act on idle of heat. The payload gives 'idle' of 'heat', while Domoticz expects 'idle' or 'heating' . This mismatch logs a error in the domoticz logfile
Error: mqtt: Climate device invalid/unknown action mode received!
The zigbee2mqtt log gives this payload
zigbee2mqtt/Thermostaat Vloerverwarming', payload '{"backlight_mode":"medium","child_lock":"UNLOCK","current_heating_setpoint":24.5,"deadzone_temperature":null,"factory_reset":null,"faultalarm":0,"frost_protection":"OFF","last_seen":"2025-11-20T06:33:52+01:00","linkquality":216,"local_temperature":19.9,"local_temperature_calibration":0,"max_temperature_limit":50,"preset":"manual","running_state":"heat","schedule_holiday":null,"schedule_weekday":null,"sensor":"external","system_mode":"heat","working_day":"disabled"}'
The device in Domoticz is a selector type
By 'idle' it gives 'idle' with level 10 and by 'heat' it gives 'undefined' with level -1. So I can uses this value but my errorlog is full of the error mentioned above.
Is anybody familiar with this bug and knows if it's solved in a beta release of else can someone puts this issue on the to do list?
Tnx
Hans
Tnx
Hans
