Fibaro Wall Plug (type 0602, id 1004) detected as “Unknown” in Domoticz 2025.2
Posted: Saturday 15 November 2025 17:14
by WickedW
Hi everyone,
Version: 2025.2
Build Hash: e63981b18
Z-Wave controller:
Aeotec Z-Stick Gen5+
Issue:
I added a Fibaro Wall Plug, but Domoticz shows it as:
“Unknown: type=0602, id=1004+”
No configuration parameters or proper device information appear.
What I have already tried:
• Node Interview / Refresh Node Info
• Removed and re-added the device
• Restarted Domoticz
• Unplugged/replugged the Wall Plug
• Updated Domoticz to version 2025.2
Question:
Is this specific model (Fibaro type 0602, id 1004) supported by the current OpenZWave configuration used in Domoticz?
If not, which XML file or entry should be added to support this device correctly?
Can someone confirm whether this device type/id exists in the latest OZW config?
Additional info:
I can provide the full Node Information / Command Classes if needed.
Thanks in advance!
Wouter
Re: Fibaro Wall Plug (type 0602, id 1004) detected as “Unknown” in Domoticz 2025.2
Posted: Saturday 15 November 2025 20:16
OpenZwave is not maintained anymore. It is advised to move to Zwave-js-UI for just the reasons you probably have this issue.
The config file for OpenZwave devices can be found in the domoticz/Config folder
