Version: 2025.2
Platform: Raspberry Pi 3 Model B Rev 1.2
Description: I monitor 2 Solar Edge installations via the API keys. If I add a third installation the hardware setup complete successfully, but the new device does not appear in the device list. Is there a limited number of Solar Edge systems Domoticz supports, or has anyone experienced a similar situation and found a solution to this issue?
Solar Edge API 3th installation issue
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2026.3
Re: Solar Edge API 3th installation issue
Nothing strange in the Domoticz log when you update the solaredge hardware gateway?
