Lost gas metering when swapped to new power meter
Posted: Friday 07 November 2025 23:19
by Jeweettoch13
Hi folks,
Due to some vague connection problems and 2G phasing out, the electrical company swapped out the power meter for a new one. The gas meter is coupled to the power meter which reads the serial number correctly.
Only problem what I'm facing now is when I started up docker trough the synology and booting the usual steps, the gasdata won't come trough.
The log on domoticz says the following:
port: /dev/ttyUSB0
2025-11-07 23:17:13.412 Status: P1: Worker started...
2025-11-07 23:17:14.134 Status: P1: Meter reports as ESMR 5.0
2025-11-07 23:17:14.176 Status: P1: Found gas meter on M-Bus channel 1
So it sees the gas meter but wont update the data.
What's the best to do to get the data read again?
Screenshot_20251107_232444_Firefox Nightly.jpg (228.48 KiB) Viewed 2573 times
Re: Lost gas metering when swapped to new power meter
Posted: Saturday 08 November 2025 0:39
Check the non reporting gas meter section on the Wiki https://wiki.domoticz.com/Dutch_DSMR_sm ... g_any_data
Posted: Saturday 08 November 2025 8:13
by Jeweettoch13
Tnx for the headsup. I tried all 4 channels individually, but it won't budge.
2025-11-08 08:06:29.973 Status: : Gas meter M-Bus channel 2 (tried 1 till 4) enforced by 'P1GasMeterChannel' user variable
2025-11-08 08:06:29.973 Status: P1: Using serial port: /dev/ttyUSB0
All other readings on behalf of uasge and return etc are working fine, so the connection is there.
Status: P1: Worker stopped...
2025-11-08 08:11:37.536 Status: P1: Using serial port: /dev/ttyUSB0
2025-11-08 08:11:37.538 Status: P1: Worker started...
2025-11-08 08:11:37.829 Status: P1: Meter reports as ESMR 5.0
2025-11-08 08:11:37.871 Status: P1: Found gas meter on M-Bus channel 1
2025-11-08 08:11:38.875 P1: P1 Smart Meter (Vermogen)
2025-11-08 08:12:24.876 P1: General/Voltage (Voltage L1)
2025-11-08 08:12:24.878 P1: General/Voltage (Voltage L2)
2025-11-08 08:12:24.879 P1: General/Voltage (Voltage L3)
2025-11-08 08:12:24.881 P1: Usage (Verbruik P1)
2025-11-08 08:12:24.882 P1: Usage (Verbruik P2)
2025-11-08 08:12:24.884 P1: Usage (Verbruik P3)
2025-11-08 08:12:24.885 P1: Usage (Teruglevering P1)
2025-11-08 08:12:24.886 P1: Usage (Teruglevering P2)
2025-11-08 08:12:24.888 P1: Usage (Teruglevering P3)
2025-11-08 08:12:24.889 P1: Current (Verbruik I1/I2/I3)
Posted: Saturday 08 November 2025 22:45
Are you on a recent Domoticz version?
There were some changes in P1 last years.
Else check the telegram that is coming out of the P1 meter:
sudo service domoticz stop
sudo cu -l /dev/ttyUSB0 -s 115200
sudo service domoticz start
Posted: Sunday 09 November 2025 8:31
by Jeweettoch13
I'm still running 2022.1 (build 14394) on DSM 7.0. It was quite the work to get it all running and when it all worked I didn't touch it anymore.
Posted: Sunday 09 November 2025 9:49
Once you have docker running, and you have a custom start.sh for installing your plugin requirements if needed , it should be easy to update.
Posted: Sunday 09 November 2025 14:35
by gizmocuz
Also check if you have a new device (and make sure accept new devices is enabled in the settting)
But this is quite old, almost 4 years!?! You should really update!
Why not spin up another instance of Domoticz and try the P1 meter hardware?
Not sure what NAS version you are using, and if you have the possibility to run dockers, but if yes, spin up a new docker.
Else just try Domoticz on your windows computer/laptop (or linux) plug in the USB 2 P1 cable and test
Posted: Sunday 09 November 2025 15:24
by Jeweettoch13
Yeah i know. It was a bit fiddly but are now on the latest 2025 version. (running 920+ DSM 7.0)
Still no gasmeter data.
I will call the company tomorrow who had it replaced. I'm sure the guy didn' t pair it properly. (can dee the gasmeter serial number in the powermeter but no usage)
Posted: Sunday 09 November 2025 17:02
by Jeweettoch13
Spinning up a clean one is a good idea yeah. I get all data, except the darn gas meter.
Posted: Monday 10 November 2025 7:39
by gizmocuz
It indeed seems that it is not paired correctly.
You should be able to see the gas meter on the display of the P1 meter
Posted: Monday 10 November 2025 12:20
by Jeweettoch13
Got a reply from the company (Liander)
They said it takes up to 1 month to get the new power meter to read the gasmeter correctly. The connection should be fine because it reads the serial number correctly.
To be continued.. I'll keep posted.
Posted: Thursday 13 November 2025 18:15
by Jeweettoch13
He's back :)
Posted: Thursday 13 November 2025 18:50
Great! Have fun with monitoring it :)
Posted: Thursday 13 November 2025 21:33
by Jeweettoch13
waltervl wrote: Thursday 13 November 2025 18:50 Great! Have fun with monitoring it :)
Tnx for the help, and eventually updating it ;)
