Logging - MQTT Auto Discover
Posted: Sunday 02 November 2025 15:57
by madpatrick
I just took a giant leap to install MQTT Auto Discover to replace OZW
It is a lot of work to get all devices back and configured, but i'm getting there
The strange thing is that i see a lot of update mesage from some devices.
2025-11-02 15:53:04.221 MQTT Auto Discover: Usage/Electric (Wnk - TV)
2025-11-02 15:53:14.021 MQTT Auto Discover: Temp/THR128/138, THC138 (Badkamer_climate))
2025-11-02 15:53:14.138 MQTT Auto Discover: General/kWh (Badkamer_electric_kwh_value_1))
2025-11-02 15:53:14.145 MQTT Auto Discover: Temp/THR128/138, THC138 (Badkamer_temperature_air_3))
2025-11-02 15:53:14.252 MQTT Auto Discover: General/kWh (Badkamer_electric_kwh_value_1))
2025-11-02 15:53:14.266 MQTT Auto Discover: Temp/THR128/138, THC138 (Badkamer_temperature_air_4))
2025-11-02 15:53:19.214 MQTT Auto Discover: Lux/Lux (PIR Lux)
2025-11-02 15:53:37.218 MQTT Auto Discover: General/kWh (Wnk - TV_electric_kwh_value))
2025-11-02 15:53:37.230 MQTT Auto Discover: Usage/Electric (Wnk - TV)
2025-11-02 15:53:38.217 MQTT Auto Discover: General/kWh (Wnk - TV_electric_kwh_value))
2025-11-02 15:53:38.225 MQTT Auto Discover: Usage/Electric (Wnk - TV)
2025-11-02 15:53:39.165 Logitech Media Server: (Squeezebox Touch) Playing - 'Zucchero Fornaciari & Paul Young - Senza Una Donna'
2025-11-02 15:53:45.769 MQTT Auto Discover: Temp + Humidity/THGN122/123/132, THGR122/228/238/268 (Badkamer_battery_level))
2025-11-02 15:54:14.011 MQTT Auto Discover: General/kWh (Badkamer_electric_kwh_value_1))
2025-11-02 15:54:14.122 MQTT Auto Discover: General/kWh (Badkamer_electric_kwh_value_1))
2025-11-02 15:54:14.132 MQTT Auto Discover: Usage/Electric (Badkamer [W1])
2025-11-02 15:54:14.238 MQTT Auto Discover: General/Voltage (Badkamer_electric_v_value_1))
2025-11-02 15:54:14.351 MQTT Auto Discover: Temp/THR128/138, THC138 (Badkamer_climate))
2025-11-02 15:54:14.465 MQTT Auto Discover: General/kWh (Badkamer_electric_kwh_value_1))
2025-11-02 15:54:14.472 MQTT Auto Discover: Temp/THR128/138, THC138 (Badkamer_temperature_air_3))
2025-11-02 15:54:14.579 MQTT Auto Discover: General/kWh (Badkamer_electric_kwh_value_1))
2025-11-02 15:54:14.593 MQTT Auto Discover: Temp/THR128/138, THC138 (Badkamer_temperature_air_4))
Is there a way to disable this log entries ??
I've set the log level in the Z-wave-JS UI to Info
2025-11-02 15_56_40-toon – _VM Domoticz 1 – WinSCP.png (24.06 KiB) Viewed 1682 times
Re: Logging - MQTT Auto Discover
Posted: Sunday 02 November 2025 16:38
by gizmocuz
The log settings from Domoticz is separate from ZWaveJS-UI
You can click on the MQTT AD hardware in domoticz and change the log settings here
You also did not install MQTT Auto Discover, but you installed ZWaveJS-UI.
Posted: Sunday 02 November 2025 16:39
by madpatrick
ah. That simple
Thanks for the swift reply
