Pull down menu Serial Port installing P1 smart meter is empty
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
PaulBridge
Post by PaulBridge »
I have done a new installion of Domoticz on my Rapsberry PI v3. I installed Domoticz under (?) Docker. Looks OK. Buienradar nl works perfectly, but when I try to install in "hardware" my P1 smart meter, I cannot define the Serial Port. Pull Down menu is empty. I have tried everything I could find online.
I checked that input from the meter is entering the Raspberry OK.
Re: Pull down menu Serial Port installing P1 smart meter is empty
If you use Docker you have to map your RPi serial device to a docker serial device in the docker compose file.
See section serial port on the wiki page about the docker install. https://wiki.domoticz.com/Docker#Serial_Port
