Python Plugin: WeHeat
jorknu
Post by jorknu »
Recently had a WeHeat Sparrow heatpump installed.
WeHeat is a Dutch manufacturer of heatpump with a data driven approach.
They have given to the community a HA integration and put on github a python client library:
https://github.com/wefabricate/wh-python
In an effort to learn some python I have decided to make a domoticz plugin out of the client library.
Source code can be found:
https://github.com/Tableflipper9001/weh ... icz-plugin
The following can be found from the Readme in github (most accurate):
  • Installation instruction, highly advisable to use a python virtual environment
  • Version history
  • List of known problems / TODO's
This plugin has been tested with:
Domoticz 2025.1, 2025.2 - Raspberry pi 3B, RPI OS 12 with a WeHeat Sparrow P60 (Hybrid system, gas boiler via On/Off)
I have checked with a collegeau who has a Blackbird (P80), the parameter set looks the same, so no problems expected for the other heatpumps.
Looking for people to confirm that the plugin also works for:
  • Blackbird P60 / P80 - All electric
  • Blackbird P60 / P80 - Hybrid (On/Off or OT)
  • Sparrow P60 - All electric
  • Flint P40 - All electric
  • Flint P40 - Hybrid (On/Off or OT)
Also searching for people that use Windows to check if the plugin functions.
Current capability of the plugin is:
  • Temperature - Room temperature
  • Temperature - Room temperature setpoint
  • Temperature - Heating flow temperature
  • Temperature - Heating flow temperature setpoint
  • Temperature - Heatpump flow temperature
  • Temperature - Heatpump return temperature
  • Percentage - COP
  • kWh - Electrical power
  • kWh - Heat power
  • kWh - Power from air
  • Percentage - Compressor usage
  • Text - Heatpump state
  • Text - Cooling state
  • Text - Heatpump error
For Hybrid systems:
  • On/off switch - Gas boiler state
For All-Electric systems:
  • On/off switch - Electric heater state
If there are things not working or you think it should be different let me know in the comments
Greetz,
Jordy
Re: Python Plugin: WeHeat
I added it to the Plugin List on the wiki.
niki_lauda
Post by niki_lauda »
jorknu wrote: Monday 27 October 2025 20:31 Hi,
  • Version history
  • Percentage - COP
  • kWh - Heat power
For Hybrid systems:
Greetz,
Jordy
Hi Jordy
Thanks for you plug-in
I have an problem reported in github
Can you answer it?
Thx for the efforts.
jorknu
Post by jorknu »
For completion:
Apparantly I am not getting emails on my own repos in github :(.
We are picking this up via github.
