I tried updating Domoticz to 2025.2 today. Unfortunately, it went terribly wrong because I hadn't noticed this update was for Bookworm with OpenSSL 3.0, which I don't have.
Now Domoticz won't start anymore. Does anyone know if this can be fixed? My backup has an error in it and isn't working either.
HELP Domoticz stopt working after update
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Fredom
- Domoticz version: 2026.3
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2026.3
RFLink - RFXCom - Z4D 9.1 (CC2652rb)
P1 Smart Meter - KaKu
Fred
- HansieNL
Re: HELP Domoticz stopt working after update
Maybe this info can help you...
To update your OS from bullseye to bookwork you can use this guide:
https://www.cyberciti.biz/faq/update-up ... -bookworm/
Blah blah blah
Fredom
HiHansieNL wrote: Thursday 23 October 2025 21:25 Maybe this info can help you...
Thanks for your reply, I'll look into it.
Yours sincerely,
Fred
Fred
The update script also made a FULL Domoticz backup, did that have an error? https://wiki.domoticz.com/Raspberry_Pi# ... ect_updateFredom wrote: Thursday 23 October 2025 19:18 Hello,
Fredom
I've tried your suggestion in several ways. Unfortunately, I only get error messages, which means it won't work. I made a backup from a few months ago, and that works for everything except ZigBee. None of my backups include ZigBee devices, which I don't understand. The backups I always make are of the entire SD card—an image, that is. I'm currently restoring all 21 ZigBee devices. Once this is done, I'm considering doing everything again with a clean install, not with Bookworm.
Yours sincerely,
Fred
Fred
Fredom
Hi,waltervl wrote: Friday 24 October 2025 13:15The update script also made a FULL Domoticz backup, did that have an error? https://wiki.domoticz.com/Raspberry_Pi# ... ect_updateFredom wrote: Thursday 23 October 2025 19:18 Hello,
I didn't know that about those backups. I'm already restoring everything from a backup I made a few months ago (on a different SD card). I can still try your suggestion, and I definitely will. I've learned something new.
Yours sincerely,
Fred
Fred
