Envoy enphase
Posted: Sunday 19 October 2025 7:37
by edwin1234
Whats wrong here in node red,
I get an error in domoticz that invalid data is send from node red
What is wrong here?
In domoticz:
Re: Envoy enphase
Posted: Sunday 19 October 2025 10:38
You have to follow the Domoticz API/Mqtt rules and send all the requesedt values for the P1 smart meter device It needs 6 values in the sValue and not only one.
For this power plug (?) a P1 smart meter is not correct, you need the Domoticz electric (instant + counter) device.
For instant you send the WattsNow value, for counter the Wattshourslifetime value.
Re: Envoy enphase
Posted: Sunday 19 October 2025 11:36
by FireWizard
Hello @edwin1234,
What is wrong here?
Long ago gizmocuz used a P1 Smart meter device for the native Enphase integration, but changes that to an Instant +Counter device, because a solar production differs from a P1 device.
In Node Red nothing is wrong, but you send the data in the wrong format for that sensor.
But
You use an old version 2021.1 and since then Enphase pushed new firmware into your Gateway (Envoy).
This involves a new token based login procedure. This is not supported by your old Domoticz version.
It looks like the Node Red flow supports it or your Enphase has still old firmware D5.xxxx
I really recommend upgrading Domoticz and probably your OS as well.
Re: Envoy enphase
Posted: Sunday 19 October 2025 13:18
by edwin1234
Ok thanks for the answer.
Re: Envoy enphase
Posted: Sunday 19 October 2025 14:05
by gizmocuz
FireWizard wrote: Sunday 19 October 2025 11:36
I am quite sure I never did this! :mrgreen:
P1 is for P1
Re: Envoy enphase
Posted: Sunday 19 October 2025 16:21
by FireWizard
Hello @gizmocuz,
I have to refresh your mind. Fortunately you did it.
You removed it in beta 14777 and the first stable was 2023.1.
Who else could have done this :D
See the discussion in this thread: viewtopic.php?t=31959&start=40
The topic, that is mentioned in this thread has been removed.
But @edwin1234 is still using an old version 2021.1, so he has still the P1 device.
