Radon - Airthings 2960 view plus (CO2, VOC, PM2.5, PM1, temp, humidity, pression and battery)
Posted: Thursday 16 October 2025 9:22
by giton
How to integrate airthings 2960 view plus in domoticz.
1) Buy your sensor, connect it to your wifi and configure it to get it active in the Airthings dashboard https://dashboard.airthings.com
2) Configure your account in the Airthings dashboard
  • Click 'Account
    • Change your 'User settings' to :
      • Language --> English
      • Radon --> Bq/m³
      • Temperature --> Celsius
      • Pressure --> hPa
      • VOC --> ppb
      • Date format --> dd.mm.yyyy
  • Click 'Devices'
    • Click on your device
    • Note the number on 10-digits near the 'View Plus' icon (information to be used to update your script later)
3) Create an API client request in Airthings dashboard
  • Click 'Integrations'
    • Click 'Request API Client'
      • Enter 'Name' --> 'Airthings-view-plus'
      • Enter 'Description' --> ''Airthings-view-plus @home'
      • Check 'read:device:current_values'
      • Select 'Confidential'
      • Select 'Flow type' --> Client credentials (machine-to-machine)
      • Note the 'Id' and the 'Secret' (information to be used to update your script later)
4) Configure Domoticz Hardware and devices
  • Create an new 'Hardware' with type 'Dummy'
  • Create 9 virtual Sensors with type and Axis Label' such as :
    • CO2 --> Custom sensor --> ppm
    • Battery --> Percentage
    • PM2.5 --> Custom sensor --> µg/m³
    • PM1 --> Custom sensor --> µg/m³
    • Pression --> Barometer
    • VOC --> Custom sensor --> ppb
    • Radon --> Bq/m³
    • Humidity --> Humidity
    • Temperature --> Temp
5) Create Python script to retrieve data from Airthings cloud
  • Create file named '/home/pi/domoticz/scripts/python/airthings_viewplus.py' with tis content:
#!/usr/bin/env python3
Airthings Business API integration for Domoticz.
Auto-refreshes token and updates Domoticz virtual sensors with latest device values.
Also saves retrieved data to a local JSON flat file for debugging or backup.
import sys
import os
import time
import json
import requests
# === CONFIGURATION ===
CLIENT_ID = 'xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx' # Replace this with your personnel CLIEND_ID
CLIENT_SECRET = 'xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx' # Replace this with your personnel CLIEND_SECRET
DEVICE_ID = 'xxxxxxxxxx' # Replace this with your personnel DEVICE_ID
TOKEN_FILE = '/home/pi/domoticz/scripts/python/airthings_token.json' # Adapt this if needed
DATA_FILE = '/home/pi/domoticz/scripts/python/airthings_data.json' # Adapt this if needed
DOMOTICZ_URL = 'http://127.0.0.1:8080'
DOMOTICZ_IDX = {
    'co2': 228, # Replace this with your idx device reference
    'humidity': 220,# Replace this with your idx device reference
    'radon': 222,# Replace this with your idx device reference
    'temperature': 219,# Replace this with your idx device reference
    'voc': 223,# Replace this with your idx device reference
    'pressure': 224,# Replace this with your idx device reference
    'pm1': 225,# Replace this with your idx device reference
    'pm25': 226,# Replace this with your idx device reference
    'battery': 227  # Replace this with your idx device reference
# === TOKEN MANAGEMENT ===
def save_token(token_data):
    token_data['timestamp'] = int(time.time())
    with open(TOKEN_FILE, 'w') as f:
        json.dump(token_data, f)
def load_token():
    if not os.path.exists(TOKEN_FILE):
        return None
    with open(TOKEN_FILE, 'r') as f:
        token_data = json.load(f)
    expires_in = token_data.get('expires_in', 3600)
    age = int(time.time()) - token_data.get('timestamp', 0)
    if age > expires_in - 60:  # refresh 1 min early
        return None
    return token_data.get('access_token')
def request_new_token():
    url = 'https://accounts-api.airthings.com/v1/token'
    payload = {
        'grant_type': 'client_credentials',
        'client_id': CLIENT_ID,
        'client_secret': CLIENT_SECRET,
        'scope': 'read:device:current_values'
    headers = {'Content-Type': 'application/x-www-form-urlencoded'}
    response = requests.post(url, data=payload, headers=headers)
    response.raise_for_status()
    token_data = response.json()
    return token_data['access_token']
def get_token():
    token = load_token()
    if token:
        return token
    return request_new_token()
def refresh_token_if_needed(response):
    if response.status_code == 401:
    return None
# === AIRTHINGS BUSINESS API ===
def get_latest_samples(token):
    url = f'https://ext-api.airthings.com/v1/devices/{DEVICE_ID}/latest-samples'
    headers = {'Authorization': f'Bearer {token}'}
    response = requests.get(url, headers=headers)
        token = refresh_token_if_needed(response)
    return response.json()['data']
def get_device_info(token):
    url = f'https://ext-api.airthings.com/v1/devices/{DEVICE_ID}'
# === SAVE RAW DATA ===
def save_airthings_data(samples, device_info, file_path=DATA_FILE):
    try:
        data = {
            "timestamp": time.strftime("%Y-%m-%d %H:%M:%S"),
            "samples": samples,
            "device_info": device_info
        with open(file_path, 'w') as f:
            json.dump(data, f, indent=2)
    except Exception as e:
        print(f"Error saving data to {file_path}: {e}")
# === DOMOTICZ UPDATE ===
def update_domoticz(sensor, value):
    idx = DOMOTICZ_IDX[sensor]
    if sensor == 'temperature':
        url = f'{DOMOTICZ_URL}/json.htm?type=command&param=udevice&idx={idx}&nvalue=0&svalue={float(value):.1f}'
    elif sensor == 'humidity':
        url = f'{DOMOTICZ_URL}/json.htm?type=command&param=udevice&idx={idx}&nvalue={int(value)}&svalue=0'
    elif sensor == 'battery':
        url = f'{DOMOTICZ_URL}/json.htm?type=command&param=udevice&idx={idx}&nvalue=0&svalue={int(value)}'
    else:
        url = f'{DOMOTICZ_URL}/json.htm?type=command&param=udevice&idx={idx}&nvalue=0&svalue={value}'
    try:
        requests.get(url, timeout=5)
        print(f"Error updating Domoticz idx {idx}: {e}")
# === MAIN ===
def main():
    token = get_token()
    try:
        samples = get_latest_samples(token)
        device_info = get_device_info(token)
    except requests.exceptions.HTTPError as e:
        print("Error fetching data from Airthings API:", e)
        return
    #save_airthings_data(samples, device_info)
    # Update Domoticz
    update_domoticz('co2', samples.get('co2', 0))
    update_domoticz('humidity', samples.get('humidity', 0))
    update_domoticz('radon', samples.get('radonShortTermAvg', 0))
    update_domoticz('temperature', samples.get('temp', 0))
    update_domoticz('voc', samples.get('voc', 0))
    update_domoticz('pressure', samples.get('pressure', 0))
    update_domoticz('pm1', samples.get('pm1', 0))
    update_domoticz('pm25', samples.get('pm25', 0))
    update_domoticz('battery', samples.get('battery', 0))
if __name__ == '__main__':
    main()
  • Adapt the '=== CONFIGURATION ===' section with your values
6) Trigger the script using DZvents .lua scirpt (make sure that 'EventSystem (Lua/Blockly/Scripts)' is enabled in Domotics ('Settings' > 'Other' > check 'EventSystem (Lua/Blockly/Scripts)' and click 'Apply Settings')
Create file named '/home/pi/domoticz/scripts/dzVents/scripts/airthings_trigger.lua' with this content:
    active = true,
        timer = {'every 5 minutes'}
    logging = {
        level = domoticz.LOG_ERROR,
        marker = "Airthings"
    execute = function(domoticz)
        local pythonScript = "/home/pi/domoticz/scripts/python/airthings_viewplus.py"
        local handle = io.popen("python3 " .. pythonScript .. " 2>&1")
        local result = handle:read("*a")
        handle:close()
        if result ~= "" then
            domoticz.log("Error or output from script: " .. result, domoticz.LOG_ERROR)
            domoticz.log("Airthings script executed successfully", domoticz.LOG_INFO)
Here a sample data your will get in file '/home/pi/domoticz/scripts/python/airthings_data.json' if you uncomment the line '#save_airthings_data(samples, device_info)' in the python script file :
"timestamp": "2025-10-16 05:00:01",
"samples": {
"time": 1760583439,
"battery": 100,
"co2": 727.0,
"humidity": 62.0,
"pm1": 8.0,
"pm25": 8.0,
"pressure": 990.0,
"radonShortTermAvg": 98.0,
"relayDeviceType": "hub",
"rssi": 0,
"temp": 20.7,
"voc": 167.0
"device_info": {
"id": "xxxxxxxxxx", # This has been replaced but it corresponds to your device serial number
"deviceType": "VIEW_PLUS",
"sensors": [
"radonShortTermAvg",
"temp",
"humidity",
"pressure",
"co2",
"voc",
"pm1",
"pm25"
"segment": {
"id": "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx", # This has been replaced for anonymisation
"name": "View plus",
"started": "2025-10-13T08:57:31",
"active": true
"location": {
"name": "Mon domicile"
"productName": "View Plus"
Re: Radon - Airthings 2960 view plus (CO2, VOC, PM2.5, PM1, temp, humidity, pression and battery)
Posted: Thursday 16 October 2025 9:53
by waltervl
I did not check it completely but you could probably skip the python part and do the data retrieval from dzvents (login to airthings, get the json and update the Domoticz dummy devices). Makes things easier...
So something for another user to optimize....
Posted: Thursday 16 October 2025 18:04
by giton
waltervl wrote: Thursday 16 October 2025 9:53 Thanks!
Here a .lua script to be stored in '/home/pi/domoticz/scripts/dzVents/scripts/airthings.lua' that replaces the previous .lua script and the python script (domoticz may have to be restarted to get updated devices)
A pre-requisit is to install the 'dkjson' package with this command:
sudo apt update
sudo apt install lua-dkjson
local json = require("dkjson")
    active = true,
        timer = { 'every 5 minutes' }
    logging = {
        -- === CONFIGURATION ===
        local CLIENT_ID     ='xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx' -- Replace this with your personnel CLIEND_ID
        local CLIENT_SECRET =  'xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx' -- Replace this with your personnel CLIEND_SECRET
        local DEVICE_ID     =  'xxxxxxxxxx' -- Replace this with your personnel DEVICE_ID
        local TOKEN_FILE = '/home/pi/domoticz/scripts/python/airthings_token.json'
        local DOMOTICZ_URL = 'http://127.0.0.1:8080'
        local IDX = {
            co2 = 228, --Replace this with your idx device reference
            humidity = 220, --Replace this with your idx device reference
            radon = 222, --Replace this with your idx device reference
            temperature = 219, --Replace this with your idx device reference
            voc = 223, --Replace this with your idx device reference
            pressure = 224, --Replace this with your idx device reference
            pm1 = 225, --Replace this with your idx device reference
            pm25 = 226, --Replace this with your idx device reference
            battery = 227 --Replace this with your idx device reference
        -- === FUNCTIONS ===
        local function saveToken(data)
            data.timestamp = os.time()
            local file = io.open(TOKEN_FILE, "w")
            if file then
                file:write(json.encode(data))
                file:close()
        local function loadToken()
            local file = io.open(TOKEN_FILE, "r")
            if not file then return nil end
            local content = file:read("*a")
            file:close()
            local token_data, _, err = json.decode(content)
            if not token_data or err then return nil end
            local expires = token_data.expires_in or 3600
            local age = os.time() - (token_data.timestamp or 0)
            if age > (expires - 60) then
                return nil
            return token_data.access_token
        local function requestNewToken()
            local payload = string.format(
                "grant_type=client_credentials&client_id=%s&client_secret=%s&scope=read:device:current_values",
                CLIENT_ID, CLIENT_SECRET
            local cmd = string.format(
                "curl -s -X POST -H 'Content-Type: application/x-www-form-urlencoded' " ..
                "-d \"%s\" https://accounts-api.airthings.com/v1/token", payload
            local handle = io.popen(cmd)
            handle:close()
            local token_data = json.decode(result)
            if not token_data or not token_data.access_token then
                domoticz.log("Error retrieving new token", domoticz.LOG_ERROR)
                return nil
            saveToken(token_data)
        local function getToken()
            local token = loadToken()
            if token then return token end
            return requestNewToken()
        local function fetchData(url, token)
            local cmd = string.format("curl -s -H 'Authorization: Bearer %s' %s", token, url)
            handle:close()
            if result == "" then return nil end
            local data = json.decode(result)
            return data
        local function updateDomoticz(sensor, value)
            local idx = IDX[sensor]
            if not idx then return end
            local svalue = tostring(value)
            local url
            if sensor == 'temperature' then
                url = string.format("%s/json.htm?type=command&param=udevice&idx=%d&nvalue=0&svalue=%.1f", DOMOTICZ_URL, idx, value)
            elseif sensor == 'humidity' then
                url = string.format("%s/json.htm?type=command&param=udevice&idx=%d&nvalue=%d&svalue=0", DOMOTICZ_URL, idx, value)
            elseif sensor == 'battery' then
                url = string.format("%s/json.htm?type=command&param=udevice&idx=%d&nvalue=0&svalue=%d", DOMOTICZ_URL, idx, value)
                url = string.format("%s/json.htm?type=command&param=udevice&idx=%d&nvalue=0&svalue=%s", DOMOTICZ_URL, idx, svalue)
            os.execute(string.format("curl -s '%s' > /dev/null", url))
        -- === MAIN LOGIC ===
        -- domoticz.log("Fetching Airthings data...", domoticz.LOG_INFO)
        local token = getToken()
        if not token then
            domoticz.log("No valid token; aborting", domoticz.LOG_ERROR)
            return
        local baseUrl = "https://ext-api.airthings.com/v1/devices/" .. DEVICE_ID
        local samplesData = fetchData(baseUrl .. "/latest-samples", token)
        if not samplesData or not samplesData.data then
            domoticz.log("Error fetching Airthings samples", domoticz.LOG_ERROR)
            return
        local s = samplesData.data
        --domoticz.log("Updating Domoticz with latest Airthings readings", domoticz.LOG_INFO)
        updateDomoticz('co2', s.co2 or 0)
        updateDomoticz('humidity', s.humidity or 0)
        updateDomoticz('radon', s.radonShortTermAvg or 0)
        updateDomoticz('temperature', s.temp or 0)
        updateDomoticz('voc', s.voc or 0)
        updateDomoticz('pressure', s.pressure or 0)
        updateDomoticz('pm1', s.pm1 or 0)
        updateDomoticz('pm25', s.pm25 or 0)
        updateDomoticz('battery', s.battery or 0)
        --domoticz.log("Airthings data update completed", domoticz.LOG_INFO)
Posted: Thursday 16 October 2025 19:49
by waltervl
Why dkjson? Dzvents already has a JSON library...
And you can store the token in a user variable so no need to use a file for that.
And for fetch data do not use the external curl command but the dzvents asynchronous OpenUrl function. Much more reliable and not haltingvthe Domoticz system.
And for updating devices use the dzvents device set commands....
Posted: Thursday 16 October 2025 21:48
by giton
waltervl wrote: Thursday 16 October 2025 19:49 Why dkjson? Dzvents already has a JSON library...
Here an updated version of the .lua script (pre-requisit: create uservariable named 'AirthingsToken' with variable type 'String' :
    active = true,
        timer = { 'every 5 minutes' },
        httpResponses = { 'AirthingsTokenResponse', 'AirthingsDataResponse' }
    logging = {
        local TOKEN_VAR = 'AirthingsToken'  -- Token stored manually in Domoticz user variables
        local IDX = {
        -- === TOKEN HANDLING ===
            local var = domoticz.variables(TOKEN_VAR)
            if not var or var.value == '' then return nil end
            local token_data = domoticz.utils.fromJSON(var.value)
            if not token_data or not token_data.access_token then return nil end
                return nil
        local function saveToken(token_data)
            token_data.timestamp = os.time()
            if var then
                var.set(domoticz.utils.toJSON(token_data))
                domoticz.log("User variable '" .. TOKEN_VAR .. "' not found. Please create it manually (type String).", domoticz
.LOG_ERROR)
            domoticz.openURL({
                url = "https://accounts-api.airthings.com/v1/token",
                method = "POST",
                headers = { ["Content-Type"] = "application/x-www-form-urlencoded" },
                postData = payload,
                callback = "AirthingsTokenResponse"
        local function fetchData(token)
            local url = "https://ext-api.airthings.com/v1/devices/" .. DEVICE_ID .. "/latest-samples"
            domoticz.openURL({
                url = url,
                method = "GET",
                headers = { ["Authorization"] = "Bearer " .. token },
                callback = "AirthingsDataResponse"
	local function humidityStatus(h)
	    if h < 30 then return 2
	    elseif h > 70 then return 3
	    else return 0
        -- === HANDLE RESPONSES ===
        if item.isHTTPResponse then
            if item.callback == 'AirthingsTokenResponse' then
                if item.isError or item.statusCode ~= 200 then
                    domoticz.log("Error fetching token: " .. tostring(item.statusText), domoticz.LOG_ERROR)
                    return
                local token_data = domoticz.utils.fromJSON(item.data)
                if token_data and token_data.access_token then
                    fetchData(token_data.access_token)
                    domoticz.log("Invalid token response", domoticz.LOG_ERROR)
                return
            if item.callback == 'AirthingsDataResponse' then
                    domoticz.log("Error fetching Airthings data: " .. tostring(item.statusText), domoticz.LOG_ERROR)
                    return
                local samplesData = domoticz.utils.fromJSON(item.data)
                    domoticz.log("Invalid Airthings data", domoticz.LOG_ERROR)
                    return
                if IDX.temperature and domoticz.devices(IDX.temperature) then
                    domoticz.devices(IDX.temperature).updateTemperature(s.temp or 0)
		if IDX.humidity and domoticz.devices(IDX.humidity) then
		    domoticz.devices(IDX.humidity).updateHumidity(s.humidity or 0, humidityStatus(s.humidity or 0))
                if IDX.co2 and domoticz.devices(IDX.co2) then
                    domoticz.devices(IDX.co2).updateCustomSensor(s.co2 or 0)
                if IDX.radon and domoticz.devices(IDX.radon) then
                    domoticz.devices(IDX.radon).updateCustomSensor(s.radonShortTermAvg or 0)
                if IDX.voc and domoticz.devices(IDX.voc) then
                    domoticz.devices(IDX.voc).updateCustomSensor(s.voc or 0)
                if IDX.pressure and domoticz.devices(IDX.pressure) then
                    domoticz.devices(IDX.pressure).updateBarometer(s.pressure or 0)
                if IDX.pm1 and domoticz.devices(IDX.pm1) then
                    domoticz.devices(IDX.pm1).updateCustomSensor(s.pm1 or 0)
                if IDX.pm25 and domoticz.devices(IDX.pm25) then
                    domoticz.devices(IDX.pm25).updateCustomSensor(s.pm25 or 0)
                if IDX.battery and domoticz.devices(IDX.battery) then
                    domoticz.devices(IDX.battery).updatePercentage(s.battery or 0)
                return
        -- === MAIN EXECUTION (timer) ===
        if item.isTimer then
            if token then
                fetchData(token)
                requestNewToken()
Posted: Thursday 16 October 2025 22:08
by waltervl
Yes, this look more like it! Well done!
Posted: Friday 07 November 2025 10:25
by giton
Here an updated version of the script to handle 2 Airthings view plus 2960 devices
(Restart Domoticz after configuration if you do not get your devices updated in Domoticz)
Once the devices have been created, you can update the following script like this :
    active = true,
        httpResponses = { 'AirthingsTokenResponse', 'AirthingsDataResponse1', 'AirthingsDataResponse2' }
    logging = {
        level = domoticz.LOG_ERROR, -- use LOG_DEBUG for detailed output
        -- Two Airthings devices (serial numbers)
        local DEVICE_IDS = {
            [1] = 'xxxxxxxxxx',  -- Replace this with your device #
            [2] = 'yyyyyyyyyy'   -- Replace this with your device #
        -- Domoticz IDX mapping for each device (adjust to your setup)
        local IDX = {
            [1] = { temperature=219, humidity=220, co2=228, radon=222, voc=223, pressure=224, pm1=225, pm25=226, battery=229 },
            [2] = { temperature=238, humidity=237, co2=233, radon=236, voc=235, pressure=234, pm1=231, pm25=230, battery=232 }
        local API_BASE = 'https://ext-api.airthings.com/v1/devices/'
                return nil -- token expired or about to expire
            if var then
                domoticz.log("User variable '" .. TOKEN_VAR .. "' not found. Please create it manually (String type).", domoticz.LOG_ERROR)
            domoticz.openURL({
                method = "POST",
                postData = payload,
        -- === API DATA REQUEST ===
        local function fetchData(token, deviceIndex)
            local deviceID = DEVICE_IDS[deviceIndex]
            local callbackName = "AirthingsDataResponse" .. deviceIndex
            local url = API_BASE .. deviceID .. "/latest-samples"
            domoticz.openURL({
                url = url,
                method = "GET",
                callback = callbackName
        -- === HELPER: Humidity status for Domoticz UI (comfort level) ===
            if h < 30 then return 2   -- dry
            elseif h > 70 then return 3 -- humid
            else return 0 end         -- normal
        -- === HELPER: Update Domoticz virtual sensors with Airthings data ===
        local function updateDeviceValues(index, data)
            local s = data.data
            local idxs = IDX[index]
            if not idxs then return end
            if idxs.temperature and domoticz.devices(idxs.temperature) then
                domoticz.devices(idxs.temperature).updateTemperature(s.temp or 0)
            if idxs.humidity and domoticz.devices(idxs.humidity) then
                domoticz.devices(idxs.humidity).updateHumidity(s.humidity or 0, humidityStatus(s.humidity or 0))
            if idxs.co2 and domoticz.devices(idxs.co2) then
                domoticz.devices(idxs.co2).updateCustomSensor(s.co2 or 0)
            if idxs.radon and domoticz.devices(idxs.radon) then
                domoticz.devices(idxs.radon).updateCustomSensor(s.radonShortTermAvg or 0)
            if idxs.voc and domoticz.devices(idxs.voc) then
                domoticz.devices(idxs.voc).updateCustomSensor(s.voc or 0)
            if idxs.pressure and domoticz.devices(idxs.pressure) then
                domoticz.devices(idxs.pressure).updateBarometer(s.pressure or 0)
            if idxs.pm1 and domoticz.devices(idxs.pm1) then
                domoticz.devices(idxs.pm1).updateCustomSensor(s.pm1 or 0)
            if idxs.pm25 and domoticz.devices(idxs.pm25) then
                domoticz.devices(idxs.pm25).updateCustomSensor(s.pm25 or 0)
            if idxs.battery and domoticz.devices(idxs.battery) then
                domoticz.devices(idxs.battery).updatePercentage(s.battery or 0)
            domoticz.log("Airthings: device " .. index .. " updated successfully", domoticz.LOG_INFO)
        -- === HANDLE API RESPONSES ===
            -- Handle token response
                    return
                    -- Fetch both devices after successful token retrieval
                    fetchData(token_data.access_token, 1)
                    fetchData(token_data.access_token, 2)
                return
            -- Handle device data responses
            for i = 1, 2 do
              --i = 1
                if item.callback == "AirthingsDataResponse" .. i then
                        domoticz.log("Error fetching Airthings data (device " .. i .. "): " .. tostring(item.statusText), domoticz.LOG_ERROR)
                        return
                        domoticz.log("Invalid Airthings data for device " .. i, domoticz.LOG_ERROR)
                        return
                    updateDeviceValues(i, samplesData)
                    return
        -- === MAIN EXECUTION (TIMER TRIGGER) ===
            if token then
                -- Use existing token
                fetchData(token, 1)
                fetchData(token, 2)
                -- Request new token if missing or expired
                requestNewToken()
