Raspberry OS 13/Trixie is out!
Posted: Monday 06 October 2025 11:51
by lost
Since a few days already, but did not saw the info until today:
https://www.raspberrypi.com/news/trixie ... rry-pi-os/
Re: Raspberry OS 13/Trixie is out!
Posted: Monday 06 October 2025 11:57
by waltervl
And already installation issues reported for a fresh install of Domoticz 2025.1 stable.
viewtopic.php?t=43987
Posted: Friday 24 October 2025 9:07
by jannl
Regarding Trixy, anyone succeeded in booting headless?
My pi only starts with a keyboard connected. I tried several thinks (google and copilot), but so far no luck.
Posted: Friday 24 October 2025 10:36
by Rik60
I have done a fresh Trixie install on a Rpi3B+, headless. I had to wait a few minutes before i could login. After this i installed Domoticz Stable 2025.2. No major problems, just a small problem with Z4D, but that was quick solved. Have you modified the settings in Raspberry Pi Imager?
Posted: Friday 24 October 2025 11:11
by jannl
I am using it for building Domoticz from scratch, but the pi won't boot without keyboard.
What is Z4D?
I do not use the imager, but I did the settings, first boot is always via monitor/keyboard.
I just need to check the timezone
Posted: Friday 24 October 2025 11:31
by Rik60
jannl wrote: Friday 24 October 2025 11:11
What is Z4D?
Z4D is Zigbee for Domoticz. Was just for information, not a part of your problem.
I always use the Pi imager, have never problems with the first boot headless without connecting a keyboard/monitor
Posted: Friday 24 October 2025 12:09
by HansieNL
If you are using imager 1.96 there is a bug: [BUG]:Enabling SSH does not enable SSH #1242
See:
https://github.com/raspberrypi/rpi-imager/issues/1242
I used an older version to write the image:
https://github.com/raspberrypi/rpi-imager/releases
Posted: Friday 24 October 2025 12:16
by jannl
ssh is enabled, it just does not boot without a keyboard attached.
So far no luck with google/ai etc. I just bricked the OS on my ssd for some reason and started over again
Posted: Friday 24 October 2025 14:03
by Rik60
Hmm, i am using V1.9.6, it worked for me. #1242 has only affect on Bookworm in combination with Rpi5, 500 as discribed in #1242?
Posted: Friday 24 October 2025 14:28
by jannl
Eventually I used rpi imager, but same result. No headless boot without keyboard.
I guess buying a USB HID (fake keyboard) is the way to go. Things obviuosly have changed in Trivy compared to older OS-ses
Posted: Friday 24 October 2025 16:05
by lost
What is your PI version & boot mode in use (classical uSD or USB attached external storage)?
This may make a difference compared to others that does not experiment this issue... and maybe provide keywords for better targeted web search for possible reasons and workarounds.
Posted: Saturday 25 October 2025 21:56
by jannl
I was using a pi 3b with an ssd.
I yesterday bought a pi 5 and will check tommorow I think
Posted: Sunday 26 October 2025 10:19
by jannl
It works now.
Using a Pi 5, trixy lite set to the ssd with rpi imager and using a raspberry powersupply.
I guess the Pi5 and the new powersupply did the trick. The powersupply I use with the pi 3b always worked, but maybe trivy uses a bit more power which let the headless boot fail without keboard.
Posted: Friday 02 January 2026 19:44
by mcipjvw
Hey all,
I installed domoticz on a pi4 with trixie. All seemed to work, except Python plugins!!
The log said "unable to load python..." when it tries to load my plugins. After some digging I found out that domoticz is built with older Python. Not the version that comes with trixie: Python 3.13. It is not that trivial to install the required libraries besides 3.13. Reason for me to stick to bullseye for now, and ignore the latest Domoticz update 2025.2 update. Domoticz crashes due to OpenSSL 3.0...
Seems that Domoticz narrows its OS compatibility to just bookworm at the moment.
BR Martin
Posted: Friday 02 January 2026 23:03
by waltervl
Where did you get that assumption? Domoticz should work with python 13....
Posted: Saturday 03 January 2026 16:55
by mcipjvw
Thanks for your reply. Maybe I am wrong, but I checked the next:
First, my domoticz logfile says:
Status: PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform
Checking my RPI system:
pi@raspberrypi:~/domoticz $ python3 --version
Python 3.13.5
and to be sure:
pi@raspberrypi:~/domoticz $ sudo apt install libpython3.13
libpython3.13 is already the newest version (3.13.5-2).
After some googling, I concluded that domoticz is searching for libpython3.10 libraries, and are obviously not there causing the plugin system to fail. I admit, a pretty fast conclusion. Please, give me a hint to solve this.
BR Martin
Posted: Saturday 03 January 2026 17:12
by waltervl
Support for Python 3.13 was already enabled in stable 2025.1
https://wiki.domoticz.com/Using_Python_ ... _Raspbian)
Did you install python3-dev:
Posted: Saturday 03 January 2026 17:46
by mcipjvw
This was it. Thank you for the quick help.
Would be nice that the domoticz installer checks this
BR Martin
Posted: Saturday 03 January 2026 23:25
by akamming
I move all my services (including domoticz) to docker. This presents issues like this…
Posted: Saturday 03 January 2026 23:46
by waltervl
akamming wrote: Saturday 03 January 2026 23:25
And introduces other issues but let us not elaborate on this here.....
