Enphase device gives error message
Posted: Tuesday 30 September 2025 13:54
by freekdk
Version: 2025.1
Platform: openSUSE Leap 15.6
Plugin/Hardware: Enphase
At least since September 5th hardware Enphase does not collect any data and gives:
Invalid data received! (production/json)
The cause might be that the token was no longer valid and it looks as if no new token could be obtained.
Today I removed the hardware and tried to re-enable it with a user-id and password that has been renewed, but still I get the same error message. In User Variables I see three entries, the third one, with Production in the name, has a value 0, the other two are empty.
Any suggestion for a solution?
Re: Enphase device gives error message
Posted: Tuesday 30 September 2025 14:41
by FireWizard
Hi, @freekdk,
The owner of an Enphase installation will get a token that expires after a year and an installer will get one, that expires after 12 hours.
If the token has expired or has got lost for another reason, you will need a new token and a new Session_ID.
And there is the issue:
See my post of September 20, 2025:
viewtopic.php?p=328380#p328380
The new documentation of June 2025, you will find here:
https://enphase.com/download/iq-gateway ... sing-token.
I have been able to solve it for Node-RED, with the help of
https://github.com/Maarten234/Enphase-E ... d/issues/3,
but I'm not able to do that for the native Domoticz solution. Lack of knowledge of C++.
Maybe this will help you.
Posted: Tuesday 30 September 2025 19:07
by freekdk
Hi @FireWizard
Thanks for the answer. I already guessed that an invalid token was the cause. Somehow this token is saved in a User Variable, which gets created with a suffix of the harware-id, but it does not contain a requested token. Apparently the code to get a new token in the code needs some changes. However I have no idea where and how to do that. I did read the new documentation of Enphase and I am trying to find the proper commands in a bash script to get such a token. I already have one via the webbrowser and I am able to read counter values etc.
Thanks anyway. Maybe I will write a Python script to "replace" the code in Domoticz. I already wrote such scripts for HomeWizard devices.
Regards.
Posted: Friday 03 October 2025 10:42
by freekdk
I found the location in the code and indeed the used URL there needed change. I made issue #6395 and got a reaction that it is repaired in beta 16800. Still waiting to have it appear in the stable version.
