Version : 17523 and 17748
Plateforme : Linux / debian 13.1
Plugin/Matériel : CPU intel, motherboard ASROCK, USB zwave.me, Teleinfo, MQTT
Hello
I have tested the latest version realease., 17523.
It has been installed since the end of March.
Since April 14th, it has been crashing every 3 hours, sometimes as frequently as every 3 minutes.
No changes have been made to Domoticz.
Here is the list of updated packages.
Start-Date: 2026-04-08 06:18:02
Commandline: /usr/bin/unattended-upgrade
Upgrade: openssl-provider-legacy:amd64 (3.5.5-1~deb13u1, 3.5.5-1~deb13u2), libssl-dev:amd64 (3.5.5-1~deb13u1, 3.5.5-1~deb13u2), libssl3t64:amd64 (3.5.5-1~deb13u1, 3.5.5-1~deb13u2), openssl:amd64 (3.5.5-1~deb13u1, 3.5.5-1~deb>
End-Date: 2026-04-08 06:18:05
Start-Date: 2026-04-09 06:14:01
Upgrade: libtiff6:amd64 (4.7.0-3+deb13u1, 4.7.0-3+deb13u2)
End-Date: 2026-04-09 06:14:01
Start-Date: 2026-04-10 06:59:03
Upgrade: openssh-client:amd64 (1:10.0p1-7+deb13u1, 1:10.0p1-7+deb13u2), ssh:amd64 (1:10.0p1-7+deb13u1, 1:10.0p1-7+deb13u2), openssh-server:amd64 (1:10.0p1-7+deb13u1, 1:10.0p1-7+deb13u2), openssh-sftp-server:amd64 (1:10.0p1-7>
End-Date: 2026-04-10 06:59:08
Start-Date: 2026-04-12 06:37:20
Upgrade: libgdk-pixbuf-2.0-0:amd64 (2.42.12+dfsg-4, 2.42.12+dfsg-4+deb13u1), libgdk-pixbuf2.0-common:amd64 (2.42.12+dfsg-4, 2.42.12+dfsg-4+deb13u1)
End-Date: 2026-04-12 06:37:21
Start-Date: 2026-04-16 19:12:28
Commandline: apt remove linux-image-6.12.73+deb13-amd64 --purge
Purge: linux-image-6.12.73+deb13-amd64:amd64 (6.12.73-1)
End-Date: 2026-04-16 19:12:30
Start-Date: 2026-04-16 23:35:21
Commandline: apt upgrade
Upgrade: zerotier-one:amd64 (1.16.0-2, 1.16.1)
End-Date: 2026-04-16 23:35:25
The log from domoticz
2026-04-17 17:46:29.770 Error: WebServer:464 thread seems to have ended unexpectedly (last update 67.000000 seconds ago)
2026-04-17 17:46:43.785 Error: WebServer:464 thread seems to have ended unexpectedly (last update 81.000000 seconds ago)
2026-04-17 17:46:57.801 Error: WebServer:464 thread seems to have ended unexpectedly (last update 95.000000 seconds ago)
2026-04-17 17:47:21.603 Status: Zwave.me: A DNS Error Occurred
2026-04-17 17:47:23.365 Status: Zwave.me: Value_Added: Warning: OpenZWave returned ValueLabel "Unknown" on Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Unknown, Instance: 1, Index: 0
2026-04-17 16:44:11.921 Error: Serveur hardware (3) thread seems to have ended unexpectedly
2026-04-17 16:44:25.937 Error: Serveur hardware (3) thread seems to have ended unexpectedly
2026-04-17 16:44:39.953 Error: Serveur hardware (3) thread seems to have ended unexpectedly
2026-04-17 16:44:53.969 Error: Serveur hardware (3) thread seems to have ended unexpectedly
2026-04-17 16:45:08.041 Error: WebServer:464 thread seems to have ended unexpectedly (last update 72.000000 seconds ago)
2026-04-17 16:45:08.041 Error: Serveur hardware (3) thread seems to have ended unexpectedly
I disable hardware 3, and after:
2026-04-17 17:26:38.203 Error: Weather hardware (5) thread seems to have ended unexpectedly
2026-04-17 17:26:52.219 Error: Weather hardware (5) thread seems to have ended unexpectedly
2026-04-17 17:27:06.235 Error: Weather hardware (5) thread seems to have ended unexpectedly
Since last night, I've switched to beta version 17748.
It no longer crashes, but these less serious messages remain...
2026-04-18 08:05:06.771 Error: Serveur hardware (3) thread seems to have ended unexpectedly
2026-04-18 08:05:20.786 Error: Serveur hardware (3) thread seems to have ended unexpectedly
2026-04-18 08:05:34.802 Error: Serveur hardware (3) thread seems to have ended unexpectedly
2026-04-18 08:05:48.817 Error: Serveur hardware (3) thread seems to have ended unexpectedly
2026-04-18 08:06:02.833 Error: Serveur hardware (3) thread seems to have ended unexpectedly
2026-04-18 08:06:16.849 Error: Serveur hardware (3) thread seems to have ended unexpectedly
Lastest error previous bug and stop domoticz:
2026-04-18 09:27:02.735 Debug: connection::handle_handshake Error: stream truncated
2026-04-18 09:27:02.742 Debug: connection::handle_handshake Error: stream truncated
2026-04-18 09:27:02.749 Debug: connection::handle_handshake Error: stream truncated
2026-04-18 09:27:02.752 Debug: connection::handle_handshake Error: stream truncated
2026-04-18 09:27:02.755 Debug: connection::handle_handshake Error: stream truncated
