database details
Posted: Thursday 11 September 2025 22:15
by BartSr
hi!
anyone who can point me to table/column of:
-timers of switches and the enable/disable timer switch
-same for switching notifications on off
thanks
Bart
Re: database details
Posted: Friday 12 September 2025 7:03
Use the APIs for this.
Posted: Friday 12 September 2025 7:21
by BartSr
Thanks Walter.
Can you give me some more specific info?
Posted: Friday 12 September 2025 7:48
by gizmocuz
Have a look at the documentation here
https://wiki.domoticz.com/Domoticz_API/JSON_URL%27s
Posted: Friday 12 September 2025 8:04
by BartSr
thanks Rob. Lot to dig in
Posted: Saturday 13 September 2025 11:22
by BartSr
I digged into the API and found e.g. for timers the command:
/json.htm?type=command&param=getschedules&filter=device
That's nice! But now I'm looking for the syntax to set e.g. active to false
Can I use this command?
/json.htm?type=command&param=updatetimer&idx=timerID&active=true&timertype=3&hour=0&min=20&randomness=true&command=0&days=12345</source>
So I can retrieve a full overview of all timer schedules. Did I miss same for notifications? (something like GetAllNotifications).
Or did I overlook that.
Thanks so far again.
Bart
Posted: Saturday 13 September 2025 17:34
NO, first retrieve the timers and states with the getschedules command.
Then you can enable or disable the timer you want with the call
/json.htm?type=command&param=enabletimer&idx=timerID
Or
/json.htm?type=command&param=disabletimer&idx=timerID
Posted: Saturday 13 September 2025 18:49
by BartSr
Thanks Walter. Any idea about 2nd Q?
Posted: Saturday 13 September 2025 19:17
Read the timer/schedules section of the API wiki
https://wiki.domoticz.com/Domoticz_API/ ... _Schedules
It is all there.
Posted: Saturday 13 September 2025 19:59
by BartSr
Walter, maybe you missed that 2nd Q is about notifications.
Posted: Saturday 13 September 2025 20:50
There is a notifications section in the API wiki https://wiki.domoticz.com/Domoticz_API/ ... ifications
Posted: Saturday 13 September 2025 23:06
by BartSr
Thanks Walter
I am looking for a command that lists ALL notifications just as is possible for timerschedules
Posted: Saturday 13 September 2025 23:10
There seems no such query, only per device.
It is also not needed for the normal user interface as notifications are only handled per device.
The API is created for linking the web user interface with the core program.
