Roller shutter 3 in zwave js ui
remko2000
Post by remko2000 »
I've got the Fibaro roller shutter 3 working properly in Zwave JS UI. However, I don't quite understand something. When I close my awning, it retracts properly, but then opens slightly again after a few seconds. After recalibrating, this stops happening, but the same thing happens again shortly after. What setting in the control panel could be causing this behavior? It seems to be related to some kind of voltage regulation of my awning, which is fine when I open it, but not when I close it.
solarboy
Domoticz version: 2026.4
Re: Roller shutter 3 in zwave js ui
Post by solarboy »
I have 2 of these and they do not show this behaviour. I also use zwaveJSui.
remko2000
Post by remko2000 »
solarboy wrote: Tuesday 09 September 2025 17:52 I have 2 of these and they do not show this behaviour. I also use zwaveJSui.
Can you share your settings of these devices so I can compare it with mine.
solarboy
Post by solarboy »
If you can tell me how, there are many settings and it's not possible to copy and paste. Is there a config file you would like me to upload ?
