'binary_sensor' is not supported (yet...)
renerene
Post by renerene »
Motion status is not functioning anymore on my SonOff SNZB-03 detector via Zigbee2MQTT. This is what domoticz log says:
Error: MQTT homeassistant: sending switch commands for switch type 'binary_sensor' is not supported (yet...) (0x00124b002e77fc64_battery_low_zigbee2mqtt/pirBadkamer)
Re: 'binary_sensor' is not supported (yet...)
Did you try the latest Domoticz beta?
gizmocuz
Post by gizmocuz »
You can not switch commands to a motion sensor.
This sensor should turn itself off after some seconds/minutes, probably you can configure this
If it does not, edit the motion sensor in Domoticz and specify a off delay (for example 60 seconds), they it will turn off after 60 seconds
