Unable to install Domoticz ?!
Dr No
Domoticz version: 2023-2
Post by Dr No »
I'm doing a new Domoticz installation on a 32-bit RPi3 Bookworm.
I am unable to install Domoticz ?!
At the end of process I get this :
root@PhilDom:/home/pi# curl -L install.domoticz.com | bash
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100 16889    0 16889    0     0  22719      0 --:--:-- --:--:-- --:--:-- 22719
::: You are root.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
:::    Checking for apt-utils... installed!
:::    Checking for whiptail... installed!
:::    Checking for git... installed!
:::    Checking for curl... installed!
:::    Checking for unzip... installed!
:::    Checking for wget... installed!
:::    Checking for sudo... installed!
:::    Checking for cron... installed!
:::    Checking for libudev-dev... installed!
:::    Checking for libssl1.1... installed!
:::    Checking for libcurl4... installed!
:::    Checking for libusb-0.1... installed!
::: Downloading Domoticz
::: Current User: pi
HTTP Port:  80
HTTPS Port:  443
::: Destination folder=/home/pi/domoticz
--2025-09-02 15:45:36--  http://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l
Résolution de www.domoticz.com (www.domoticz.com)… 2606:4700:3030::6815:4001, 2606:4700:3030::6815:2001, 2606:4700:3030::6815:3001, ...
Connexion à www.domoticz.com (www.domoticz.com)|2606:4700:3030::6815:4001|:80… connecté.
requête HTTP transmise, en attente de la réponse… 301 Moved Permanently
Emplacement : https://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l [suivant]
--2025-09-02 15:45:36--  https://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l
Connexion à www.domoticz.com (www.domoticz.com)|2606:4700:3030::6815:4001|:443… connecté.
requête HTTP transmise, en attente de la réponse… 403 Forbidden
2025-09-02 15:45:37 erreur 403 : Forbidden.
Where is my mistake ????
Please little help would be appreciated. (I have to leave in few days and my alarm is down)
My current system has also been down for two days.
Thank you in advance.
Re: Unable to install Domoticz ?!
Currently the Domoticz website is under ddos attack so a Cloudflare recaptcha is enabled. This unfortunately prevents installations and updates. It will become available again as soon as the attack is over.
Dr No
Post by Dr No »
Very very soon I hope
Thanks for the answer
Install/update should be working now, ddos protection is switched off for the download section of Domoticz.com
Dr No
Post by Dr No »
THANK YOU so much
I'll try this immediately
It works !!! ;) :D
