MODBUS Settings
Posted: Friday 29 August 2025 14:51
by PeterRozenveld
I tried ChatGPT< DON'T DO IT!
What settings do I need for a MODBUS H485 to read a kWh meter in Domoticz?
I used this interface:
https://github.com/DomoticX/domoticz-modbus
Re: MODBUS Settings
Posted: Friday 29 August 2025 14:58
by jvdz
Which kwh meter are you connecting this to?
Re: MODBUS Settings
Posted: Friday 29 August 2025 18:59
by PeterRozenveld
SDM630 M-bus series from Eastron,
https://commons.wikimedia.org/wiki/File ... -08-29.png
is the config by Domoticz
Re: MODBUS Settings
Posted: Friday 29 August 2025 19:14
by jvdz
Is it connected via a USB port or TCPIP as the latter is what you have configured now?
Re: MODBUS Settings
Posted: Friday 29 August 2025 20:05
by PeterRozenveld
Connected by Eastron to Interface A/B to USB to Raspberry PI
Re: MODBUS Settings
Posted: Friday 29 August 2025 22:18
by jvdz
Ok so guess you need to change the communication mode from tcpip to serial/usb then...right?
Re: MODBUS Settings
Posted: Friday 29 August 2025 23:15
There is an old python plugin for this device so perhaps you can get it running or get the modbus registers out of the code.
https://github.com/MFxMF/SDM630-Modbus/tree/master
Edit, I see gizmocuz forked it and also updated it:
https://github.com/gizmocuz/SDM630-Modbus
Re: MODBUS Settings
Posted: Saturday 30 August 2025 8:09
by PeterRozenveld
https://github.com/gizmocuz/SDM630-Modbus, so I took this link.
But I don't see any new hardware!
And to take in 22 pages of digital material, does it uberhaüpt work?
Re: MODBUS Settings
Posted: Saturday 30 August 2025 15:51
What does the log file say?
You also don't see devices created in the device list (menu Setup-Devices)?
Re: MODBUS Settings
Posted: Saturday 30 August 2025 22:50
by PeterRozenveld
Sorry, I assumed it would just appear among the hardware. Of course, I just need to add it... I just don't see any devices.
Re: MODBUS Settings
Posted: Sunday 31 August 2025 0:10
PeterRozenveld wrote: Saturday 30 August 2025 22:50
So you do not see the hardware in menu Setup - Hardware when you installed the plugin? Or don't you see devices after you installed the plugin and activated it through menu Setup - Hardware? Do you have the settings right? What does the log file say (menu Setup - Log) about the plugin?
Re: MODBUS Settings
Posted: Sunday 31 August 2025 12:43
by PeterRozenveld
https://commons.wikimedia.org/wiki/File ... -08-31.png
Okay, apologies for not being clear.
I had to add the hardware via Settings / Hardware / and the pull-down menu under “Type”: “Eastron sdm630 Modbus.” And further: “Meter Type” and set the “Baudrate” to 9600. But is it useful to set Debug to True? (See image) It's just strange that the sdm630 isn't sending any signals (Devices).
Greetings , Peter
Re: MODBUS Settings
Posted: Sunday 31 August 2025 23:54
And for the 3th time: What does the log say (menu Setup - Log) about the plugin?
And Yes, switch on debug on the plugin settings if the log does not show anything abnormal.
The ModBus ID and other settings are correct?
PS You can add the screenshot also as an attachment to your forum answer.
