Zigbee2MQTT Control Panel not loading
Posted: Tuesday 26 August 2025 16:06
by holly
the Zigbee2MQTT Plugin does not load anymore in Domoticz.
I did a git pull in /domoticz/plugins/zigbee2mqtt to get the most recent version, but it is still not loading.
Checked to have the most recent Python version, but still receive an error when I look into the browser's dev console:
http://DOMOTICZ:8080/json.htm?displayhi ... s&used=all 404 (Not Found)
(json.htm?displayhidden=1&filter=all&type=devices&used=all)
And indeed the above call does not look correct, does it?!
Shouldn't it be (at least this returns a result):
http://DOMOTICZ:8080/json.htm?type=comm ... l&used=all
(json.htm?type=command&param=getdevices&displayhidden=1&filter=all&used=all)
Any ideas what needs to be fixed?
Bye,
Holger
Version: 2025.1
Build Hash: 89d5c900d
Compile Date: 2025-05-05 09:02:49
dzVents Version: 3.1.8
Python Version: 3.9.2
Re: Zigbee2MQTT Control Panel not loading
Posted: Tuesday 26 August 2025 20:33
by waltervl
According this topic it should be fixed with an update of the plugin. viewtopic.php?t=43077
But perhaps there is still a left over of old API calls.
It is by the way better to switch to the MQTT AD gateway to connect to zigbee2mqtt... https://wiki.domoticz.com/Zigbee2MQTT#M ... toDiscover
Posted: Tuesday 26 August 2025 23:11
by holly
I know that it would be the better option to change, but I have a fairly large number of sensors / actors that I would need to assign again.
Or did I just miss an easy and automatic way of transferring Zigbee devices?
In that case I would probably also change from Domoticz to Home Assisstant.
Posted: Tuesday 26 August 2025 23:25
by holly
Problem solved!
Thanks for pointing me to topic 43077 -- I have not seen it before.
The trick seemed to be to clear the git cache --> "A git pull and clear cache did the trick."
Posted: Wednesday 27 August 2025 16:50
by holly
...one addition
it could also have been the machine/browser I was working with.
Yesterday evening I used a different notebook and it worked (after a git clear cache).
Today, my desktop computer again failed until I deleted the browser cache. So I would say it was more the machine's browser (cache) causing the issue.
