Date and leap year handling in dzvents  [Solved]
Gingerpale
Domoticz version: 2026.1
Post by Gingerpale »
How can I make this script below working correctly at leap years? Now it always adds 364 days to calculate the end contract date as I am using addDays. If I could use addYears it would be easier I guess but that attribute doesn't exist. Maybe there's an easier way.
           timer = { 'every minute'}, -- for testing only, else use 'at 00:00'
 	logging = {
           level = domoticz.LOG_DEBUG,
           marker = "timer"
	execute = function(domoticz)
       	   local Time = require('Time')
           local contractStartDate = Time(domoticz.variables("Energy_Contract_Start").date.rawDate .. ' 00:00:00')
           domoticz.log('Contract Start Date: ' .. contractStartDate.rawDate, domoticz.LOG_INFO) -- e.g. 2025-07-15
           local contractEndDate = contractStartDate.addDays(364) -- make a new time object '1 year - 1 day' later. This fails at leap years!
           domoticz.log('Contract End Date: ' .. contractEndDate.rawDate, domoticz.LOG_INFO) -- e.g. 2026-07-14
           if domoticz.time.rawDate == contractEndDate.rawDate then -- e.g. "2026-07-14"
               domoticz.log('Energy contract ends today!', domoticz.LOG_INFO)
               domoticz.log('Energy contract does not end today', domoticz.LOG_INFO)
Rpi4B,RFX433e,PiFace2, LCD, Hue bridge, Alexa (+TTS), HA-Bridge, Sonoff NSPanel, Sonoff RF (+IR) bridge, Nefit CV, Tasmota/MQTT, Enphase Solar, Smartmeter, Alarm I/F, H13726B Weather Station, CM180 Energy meter, Sonoff, KaKu, Tuya, Gledopto, AriLux,...
madpatrick
Re: Date and leap year handling in dzvents  [Solved]
Post by madpatrick »
Maybe this works
You can check the 29 februari as a leap year
    -- Extract year, month, day from start date
    local year = contractStartDate.year + 1
    local month = contractStartDate.month
    local day = contractStartDate.day
    -- Handle Feb 29 for non-leap years
    if month == 2 and day == 29 then
        -- Check if new year is leap year
        if not (year % 400 == 0 or (year % 4 == 0 and year % 100 ~= 0)) then
            day = 28
    -- Create new end date as string YYYY-MM-DD and time 00:00:00
    local endDateString = string.format('%04d-%02d-%02d 00:00:00', year, month, day)
    local contractEndDate = Time(endDateString)
Gingerpale
Hi madpatrick,
This works perfectly. Many thanks for the swift reply.
