Strange behaviour on Truenas Scale Container instance
Posted: Friday 08 August 2025 8:57
Decided to move from Rpi 3B+ to Truenas Scale docker container.
When domoticz runs on container, data from mysensors wifi gateway ("nrf gw" in log) doesn't always get through, commands are delayed about 20sec.
Same delay for sonoff wifi devices.
When I boot up Pi parallel on different IP, the data on Container gets all the values and commands are triggered instantly.
Running only on Pi has no issues.
There isn't any official app, but I've used "Custom app" function.
So the installation is triggered automatically, added few configurations for repo and port forwarding:
Image Configuration
Repository
domoticz/domoticz
Tag
stable
Pull Policy
Always pull an image even if it is present on the host.
Port Bind Mode
Publish port on the host for external access
Host Port
8081
Container Port
8080
Protocol
TCP
Host IPs
log from startup on docker, Pi is offline:
Image Configuration
Repository
domoticz/domoticz
Tag
stable
Pull Policy
Port Bind Mode
Host Port
8081
Container Port
8080
Protocol
TCP
Host IPs
2025-08-08 09:55:31.754 Launch: Begin container self-repair
2025-08-08 09:55:31.933 Launch: End container self-repair
2025-08-08 09:55:31.933 Launch: Running customstart.sh
2025-08-08 09:55:31.957 Status: Domoticz V2025.1 (build 16672) (c)2012-2025 GizMoCuz
2025-08-08 09:55:31.957 Status: Build Hash: 7f861f5bd, Date: 2025-05-05 09:31:45
2025-08-08 09:55:31.957 Status: Startup Path: /opt/domoticz/
2025-08-08 09:55:31.984 Sunrise: 05:24:00 SunSet: 21:30:00
2025-08-08 09:55:31.984 Day length: 16:06:00 Sun at south: 13:27:00
2025-08-08 09:55:31.984 Civil twilight start: 04:31:00 Civil twilight end: 22:23:00
2025-08-08 09:55:31.984 Nautical twilight start: 03:08:00 Nautical twilight end: 23:46:00
2025-08-08 09:55:31.984 There is no astronomical twilight in the space of 24 hours
2025-08-08 09:55:31.994 Status: PluginSystem: Started, Python version '3.9.2', 0 plugin definitions loaded.
2025-08-08 09:55:31.997 Active notification Subsystems: email, pushbullet (2/13)
2025-08-08 09:55:31.998 Status: WebServer(HTTP) started on address: :: with port 8080
2025-08-08 09:55:31.999 Status: WebServer(SSL) started on address: :: with port 443
2025-08-08 09:55:32.000 Starting shared server on: :::6144
2025-08-08 09:55:32.000 Status: TCPServer: shared server started...
2025-08-08 09:55:32.000 Status: RxQueue: queue worker started...
2025-08-08 09:55:34.003 Status: nrf gw: Trying to connect to: 192.***.***.***:5003
2025-08-08 09:55:34.005 Status: emaplaat: System: ODroid/Raspberry
2025-08-08 09:55:34.005 Status: emaplaat: Hardware Monitor: Started (OStype Linux)
2025-08-08 09:55:34.005 Status: Wol: Started
2025-08-08 09:55:34.005 Status: NotificationSystem: thread started...
2025-08-08 09:55:34.005 Status: EventSystem: reset all events...
2025-08-08 09:55:34.005 Status: EventSystem: reset all device statuses...
2025-08-08 09:55:34.008 Status: nrf gw: Connected to: 192.***.***.***:5003
2025-08-08 09:55:34.013 nrf gw: Gateway Ready...
2025-08-08 09:55:34.015 Status: nrf gw: Node: 0, Sketch Name: GW
2025-08-08 09:55:34.015 Status: nrf gw: Node: 0, Sketch Version: 1
2025-08-08 09:55:34.015 nrf gw: Gateway Version: 2.3.2
2025-08-08 09:55:34.029 Status: Python EventSystem: Initializing event module.
2025-08-08 09:55:34.029 Status: EventSystem: Started
2025-08-08 09:55:34.029 Status: EventSystem: Queue thread started...
Script created by hpapagaj and modified..."]:79: bad argument #1 to 'pairs' (table expected, got nil)
2025-08-08 09:55:34.060 nrf gw: Gateway Version: 2.3.2
2025-08-08 09:55:36.008 emaplaat: Temp (CPU)
2025-08-08 09:55:43.394 nrf gw: General/Custom Sensor (Tarbevee rõhk)
2025-08-08 09:55:47.635 nrf gw: Temp (Kaminast)
2025-08-08 09:55:53.162 nrf gw: Temp (Laepeal sisemine)
2025-08-08 09:55:56.013 emaplaat: General/Percentage (Memory Usage)
2025-08-08 09:55:56.014 emaplaat: General/Custom Sensor (Process Usage)
2025-08-08 09:56:03.534 nrf gw: Temp (Laepeal sisemine)
2025-08-08 09:56:03.687 nrf gw: General/Custom Sensor (Tarbevee rõhk)
2025-08-08 09:56:08.685 nrf gw: Temp (Kaminast)
