Problem Replacing Device
Posted: Friday 08 August 2025 1:47
Since I moved to 2025.1 I've had a problem with the HDD device on my Pi motherboard. The old device stopped working, I believe due to changes discussed here viewtopic.php?p=325078&hilit=motherboard#p325078
Whilst I can allow the new device to be created (which does update), if I try to replace the old one, it transfers all of the new data across then doesn't update anymore. A few seconds later a new device called HDD / is recreated
Debug logging shows the replace, the subsequent automatic deletion of the incorrect device then nothing else until I allow the recreation.
Any ideas how I can fix this given the logs don't show much?
2025-08-08 00:26:26.218 Status: Replace old device 14 to new device 718 from 2025-05-10 10:02:52.
2025-08-08 00:26:26.470 Debug: CSQLHelper::DeleteDevices: ID: 718
2025-08-08 00:26:31.282 Debug: SQLH UpdateValueInt Raspberry01 CPU HwID:1 DevID:0000044D Type:243 sType:6 nValue:0 sValue:3.02 IDX: 16
2025-08-08 00:26:31.283 Motherboard: General/Percentage (Raspberry01 CPU)
2025-08-08 00:26:51.294 Debug: SQLH UpdateValueInt HDD /boot/firmware HwID:1 DevID:0000044E Type:243 sType:6 nValue:0 sValue:12.40 IDX: 715
2025-08-08 00:26:51.295 Motherboard: General/Percentage (HDD /boot/firmware)
2025-08-08 00:26:51.299 Debug: Device creation failed, Domoticz settings prevent accepting new devices.
2025-08-08 00:29:41.352 Debug: SQLH UpdateValueInt HwID:1 DevID:00000450 Type:243 sType:6 nValue:0 sValue:57.44 IDX: 743
2025-08-08 00:29:41.353 Motherboard: General/Percentage (HDD /)
