P1 meter, trying to add net ampere sensor
Posted: Monday 04 August 2025 13:18
by akamming
I have a use case for a net ampere sensor (to send the amperages to evcc for loadbalancing purposes).
P1 meter already has a "Current" and a "Current Delivery" sensor. However what i want to add a sensor, which combines the two.
So e.g. Current is (8.6A, 0A, 0A) and Current Delivery is (0A, 2A, 2A) the value of (8.6A, -2A, -2A): Delivery is substract from normal current.
I managed to get it to work with a dzventz script, but since i have to send value every seconds, this gives way too much CPU load.. (already caused me some sync issue, cause net amperage calculated too late due to this)
So since it's holiday and i had some time, i tried to add it to the P1 code (P1meterbase.cpp), and changed the code to:
					if (
						(m_voltagel1 != -1)
						&& (m_voltagel2 != -1)
						&& (m_voltagel3 != -1)
						// The ampere is rounded to whole numbers and therefor not accurate enough
						// Therefor we calculate this ourselfs I=P/U, I1=(m_power.m_powerusel1/m_voltagel1)
						float I1 = avr_usage[0] / m_voltagel1;
						float I2 = avr_usage[1] / m_voltagel2;
						float I3 = avr_usage[2] / m_voltagel3;
						SendCurrentSensor(0, 255, I1, I2, I3, "Current L1/L2/L3");
						Log(LOG_STATUS, "Sending Current L1/L2/L3: %.2f/%.2f/%.2f", I1, I2, I3);
						// Calculate net current (usage-delivery)
						float net_I1 = I1;
						float net_I2 = I2;
						float net_I3 = I3;
						//Do the same for delivered
						if (m_powerdell1 || m_powerdell2 || m_powerdell3)
							I1 = avr_deliv[0] / m_voltagel1;
							I2 = avr_deliv[1] / m_voltagel2;
							I3 = avr_deliv[2] / m_voltagel3;
							SendCurrentSensor(1, 255, I1, I2, I3, "Delivery Current L1/L2/L3");
							Log(LOG_STATUS, "Sending Delivery Current L1/L2/L3: %.2f/%.2f/%.2f", I1, I2, I3);
							// calculate net current (usage-delivery)
							net_I1 = net_I1 - I1;
							net_I2 = net_I2 - I2;
							net_I3 = net_I3 - I3;
						// Send net current sensor
						SendCurrentSensor(2, 255, net_I1, net_I2, net_I3, "Net Current L1/L2/L3");
						Log(LOG_STATUS, "Sending Net Current L1/L2/L3: %.2f/%.2f/%.2f", net_I1, net_I2, net_I3);
(the difference with original code added the loglines for debugging. and added sensor number for calculating the net current)
When testing, in the code seems to work fine, cause it does exactly what i want it to do:
2025-08-04 13:04:58.060  Status: Slimme Meter: Sending Current L1/L2/L3: 8.59/0.00/0.00
2025-08-04 13:04:58.060  Status: Slimme Meter: Sending Delivery Current L1/L2/L3: 0.00/1.49/1.18
2025-08-04 13:04:58.060  Status: Slimme Meter: Sending Net Current L1/L2/L3: 8.59/-1.49/-1.18
2025-08-04 13:05:03.062  Status: Slimme Meter: Sending Current L1/L2/L3: 8.68/0.00/0.00
2025-08-04 13:05:03.062  Status: Slimme Meter: Sending Delivery Current L1/L2/L3: 0.00/1.50/1.18
2025-08-04 13:05:03.062  Status: Slimme Meter: Sending Net Current L1/L2/L3: 8.68/-1.50/-1.18
However the real values in the meter are all positive:
Anyone has a hint how to proceed, so the negative values are shown?
Re: P1 meter, trying to add net ampere sensor
Posted: Monday 04 August 2025 13:33
Why doing this?
You can just request both ampere devices in your evcc load balancing script?
And also Domoticz (well the hardware it is running on) could be not handling P1 updates every 1 or 5 seconds!
Posted: Monday 04 August 2025 14:14
by akamming
waltervl wrote: Monday 04 August 2025 13:33 Why doing this?
Nope, that doesn’t work. In evcc I can configurere Only 1 current device and evcc expects this to be combined Delivery and usage current.
Maybe i am wrong, but could you then send me the correct evcc config to make this work with domoticz?
Just the p1 meter every second runs fine om my pi4, I already tested
And every second is a requisite: It is used for loadbalancing, so I really need the latest p1 reading the prevent the loadbalancer kicking in too late in case of overcurrent
Posted: Monday 04 August 2025 15:16
I do not use evcc what is that?
Posted: Monday 04 August 2025 16:32
by akamming
waltervl wrote: Monday 04 August 2025 15:16 I do not use evcc what is that?
An energy management system which optimizes for the cheapest or most co2 friendly way of charging your car and/or home battery
https://evcc.io/
Posted: Monday 04 August 2025 16:39
Perhaps think of connecting your home P1 meter directly to the ecvv application, so without Domoticz. Or buy better hardware that is able to run Domoticz being updated every second with P1 data (20+ devices).
Posted: Monday 04 August 2025 21:29
by akamming
waltervl wrote: Monday 04 August 2025 16:39 Perhaps think of connecting your home P1 meter directly to the ecvv application, so without Domoticz. Or buy better hardware that is able to run Domoticz being updated every second with P1 data (20+ devices).
As stated hardware is not the issue. Pi 4b is fast enough. I am only missing a net amperage sensor.
Anyway I think I found the spot in the code where the value is made positive again, also already created a fix. Now waiting for the sun to shine to test it 😉
If it works i create a pr
Posted: Tuesday 05 August 2025 16:14
by gizmocuz
Changes are adapted in the code
