Switching on PV Power
Posted: Thursday 17 July 2025 10:09
Hello all,
i've implemented the Domotics Energy view by using P1 data from my 'slimme meter'
Some virtual devives are added by the installation script for a 3phase environment i have the device "kWh Delivery L3 (Calculated)"
Ill gives the Power wich sended back at the grid when there is enough sun on the panels. The value = 0 or positive in watts
So i want to us the script below to switch ON a Tasmota device if Power > 1000 Watt and switch off when it come's below 500 watt
below my script :
The problem is "Tas76-ZonneStroom" don't switch on when there is enough sunpower.
Can somebody help me with this script ?
Thanks a lot
Rob
below my script :
active = true,
devices = {"kWh Delivery L3 (Calculated)"}
if (domoticz.devices("Tas76-ZonneStroom").state == 'Off' and
domoticz.devices("kWh Delivery L3 (Calculated)").Watt ~= nil and
domoticz.devices("kWh Delivery L3 (Calculated)").Watt > 1000 )
then
domoticz.devices("Tas76-ZonneStroom").switchOn()
}Can somebody help me with this script ?
Thanks a lot
Rob
