update error
JuanUil
Domoticz version: 4.11083
update error
Post by JuanUil »
Hi there,
I want to update to the new version but i can not get over this:
git pull
Updating e729d55..372b8fe
error: Your local changes to the following files would be overwritten by merge:
css/creative.css
docs/blocks/domoticzblocks.rst
docs/releasenotes/releasenotes.rst
js/blocks.js
js/blocktypes.js
js/components/domoticzblock.js
js/components/group.js
js/dashticz.js
js/loader.js
js/switches.js
js/thermostat.js
package-lock.json
package.json
tpl/thermostat_block.tpl
version.txt
Please commit your changes or stash them before you merge.
Aborting
make: *** [Makefile:119: update] Fout 1
Help please
Jan
jvdz
Domoticz version: 4.107
Re: update error
Post by jvdz »
You have made "local" changes to the github repository, so you need to tell github what to do with those changes.
Do you remember why you have done them and what you changed?
gizmocuz
Re: update error
Post by gizmocuz »
If you are uncertain, you can always issue this command before updating the sources (you will loose all changes)
git reset --hard origin/development
Assuming you are on the development branch
If you are a regular user, I wont advise compiling/running from source
JuanUil
Re: update error
Post by JuanUil »
I don't remember making any changes.
When I do:
fatal: ambiguous argument 'origin/development': unknown revision or path not in the working tree.
Use '--' to separate paths from revisions, like this:
'git <command> [<revision>...] -- [<file>...]'
Re: update error
I think gizmocuz thought it was a Domoticz source files issue and not a Dashticz issue.
I think you should do the following for Dashticz to get over this issue:
git reset --hard
git pull --force
JuanUil
Re: update error
Post by JuanUil »
Thnx very much, that did the trick
