WUD - What's up docker
Varazir
Post by Varazir »
WUD has has MQTT support and say it's playing nice with home assistance.
https://getwud.github.io/wud/#/configur ... gers/mqtt/
I thought I would give it a try.
I can see my containers in my MQTT explorer
This is my setup in Domoticz
Maybe I'm doing something wrong or need some something to translate the MQTT payload in Domoticz for it to discover.
This is payload for Domoticz
https://gist.github.com/varazir/ecac2f5 ... 2a09cfc057
Show status, if there an update maybe more but it's what I come up with.
maybe with script/API trigger an update from Domoticz.
Varazir
Re: WUD - What's up docker
Post by Varazir »
I see that I missed in the docker conf
- WUD_TRIGGER_MQTT_MOSQUITTO_HASS_ENABLED=true
- WUD_TRIGGER_MQTT_MOSQUITTO_HASS_DISCOVERY=true
few devices has been created. One step forward
heggink
Domoticz version: 12451
Post by heggink »
Quite interesting! Is this compensating for the lack of update indicators in dockge?
P1 meter & solar panel
Varazir
Post by Varazir »
heggink wrote: Wednesday 09 July 2025 17:06 Quite interesting! Is this compensating for the lack of update indicators in dockge?
yes sort of and no notification in Domoticz.
Varazir
Post by Varazir »
I'm have set it up using the Python Plugin: MqttMapper plugin to do this but it seams like WUD isn't that good at pushing data to the MQTT broker.
I think I see the issue, the cron was set to run 0300
Change the cron to every 5 min.
https://github.com/FlyingDomotic/domoti ... per-plugin
Varazir
Post by Varazir »
Example
	"Dockge Status": {
		"topic": "wud/container/docker/dockge-dockge-1",
		"key": "wud/container/docker/dockge-dockge-1-status",
		"type": "244",
		"subtype": "73",
		"switchtype": "0",
		"mapping": {
			"item": "status",
			"default": "0",
			"values": {
				"running": "100"
	"Dockge Update": {
		"key": "wud/container/docker/dockge-dockge-1-update",
		"type": "244",
		"subtype": "73",
		"switchtype": "0",
		"mapping": {
			"item": "update_available",
			"default": "0",
			"values": {
				"false": "0",
				"true": "100"
So what was wrong with the HA Discovery option? From the documentation it just should work.
Varazir
Post by Varazir »
waltervl wrote: Sunday 13 July 2025 0:49 So what was wrong with the HA Discovery option? From the documentation it just should work.
With this settings
I only get this devices
This how it looks like in MQTTexplorer
Logs
Yes, and that seems correct. i see 3 binary sensors in config and 4 sensors. So in Domoticz creates 3 switches and 4 custom sensors. So exactly what WUD configured. It also should be enough to manage the system I suppose.
But perhaps in topic WUD/update also config topics are present?
It is (or was) by the way not advised to have the discovery topic (default homeassistant) the same as the main state topic.... If you want to differ better make it for example WUD_discover, zwave_discover, zigbee2mqtt_discover etc
Varazir
Post by Varazir »
waltervl wrote: Sunday 13 July 2025 10:26 Yes, and that seems correct. i see 3 binary sensors in config and 4 sensors. So in Domoticz creates 3 switches and 4 custom sensors. So exactly what WUD configured. It also should be enough to manage the system I suppose.
Don't know, But it don't show status of each container. It's what I'm after.
waltervl wrote: Sunday 13 July 2025 10:26 It is (or was) by the way not advised to have the discovery topic (default homeassistant) the same as the main state topic.... If you want to differ better make it for example WUD_discover, zwave_discover, zigbee2mqtt_discover etc
Why dose it matter ?
If I use the homeassistant topic for all will that not mash everything and domoticz will hard understand what is what?
For me it's more logic to separate them. Then dose it matter to use *_discover? Dose the the plugins care about the topic? as long as it's matching in the settings shouldn't it work ?
The discovery topic is by default split from the state topic to ease the system in discovering devices. Else every new message in the integration also has to be checked for config changes. And when you have a lot of devices you will get a lot of unnecessary possible config changes that needs to be handled.
In the past this could go wrong, this is why you see a split in config and state topics.
Varazir
Post by Varazir »
So I should change prefix tag för zwave/zigbee/wud to homeassistant?
And the in the HW setup for both I should have homeassistant?
If you use the default settings of WUD, zigbee and zwave you will see you get a zwave, zigbee and wud state topics and homeassistant topic where all the config topics are. This will not have issues if you have only 1 Domoticz MQTT AD gateway. All the devices will be handled by this gateway.
If you want a seperate Domoticz MQTT AD gateway for each integration for ease of understanding you should also define a discovery prefix for each integration (eg WUD_discover) as else Domoticz will indeed be mixing things up.
Varazir
Post by Varazir »
waltervl wrote: Monday 14 July 2025 0:21 If you use the default settings of WUD, zigbee and zwave you will see you get a zwave, zigbee and wud state topics and homeassistant topic where all the config topics are. This will not have issues if you have only 1 Domoticz MQTT AD gateway. All the devices will be handled by this gateway.
Hmm, if I change all to homeassistant and create a new HW with that topic.
Will it create new devices and I need to merge them ?
I dont know, but probably yes.
Varazir
Post by Varazir »
waltervl wrote: Tuesday 15 July 2025 12:17 I dont know, but probably yes.
I got a bunch of new devices.
This my settings and I changed WUD to be taged as homeassistant
Edit: the HA service is enabled, it just shows not when I switch between settings
So what's the correct operation.
Edit the old device and click replace? (I always mess this upp and lost a lot of history due to that)
From the wiki https://wiki.domoticz.com/Managing_Devi ... ace_device
press the Edit button on the Old device, select replace and select the new Device. (In this case the devices called ‘New UV Meter’).
Next press OK. Result:
The old and new device will be merged and get the name and IDX of the old device. This will prevent changes in scripts that use this device.
The new device will be deleted. (behavior since Stable 2022.1)
If there is a hardware gateway difference between Old and New device (eg when switching from OZW to Zwave JS UI MQTT) the merged device (with old name and idx) will get the hardware gateway of the new device.
Varazir
Post by Varazir »
Okay thanks
this doesn't make sense,
To replace the old sensor data (history logging) to the new device act as follow:
First, add (or is added by new gateway) the new device to the system, and call it for example ‘New UV Meter’.
Next press the Edit button on the Old device, select replace and select the new Device. (In this case the devices called ‘New UV Meter’).
I would change the wording to "To move old sensor data to the new device..."
Varazir
Post by Varazir »
Hmm, I switched all to homeassistant, created a new HW and replaced all the old devices I needed.
And everything still works as expected?
I changed the wiki on the replace/move wording.
