n8n webhook in dzevents
acaonweb
Post by acaonweb »
Hi everyone,
i need an help with a script.
i want create a script that trigger a device. When triggered, the script has to call a n8n webhook, and get some data.
Something like that
	-- trigger
		devices = {'Irrigatore'},
	execute = function(dz, device, tginfo)
	-- start webhook
	-- return data from webhook
	-- end webhook
the script have to wait until the call is ended.
the url is somethink like
https://IP/webhook/irrigazione
and i need to pass some a JSON
Everything is working manually with curl
curl -X GET https://IP/webhook/irrigazione  -H "Content-Type: application/json" -d '{"umidita": 59, "temperatura_esterna": 31.5, "temperatura_terriccio":31.5}'
how can do that?
Thanx in advance
Fabrizio
Re: n8n webhook in dzevents
Make use of the dzvents asynchronous openURL function.
wiki: https://wiki.domoticz.com/DzVents:_next ... P_requests
example: viewtopic.php?p=319573#p319573
