Page 1 of 5
Marstek Battery plugin
Posted: Thursday 26 June 2025 13:25
by RNEE
Last week i installed a new Marstek Venus E 5,12 Kwh homebattery.
It seems they are flooding the market with these
Runs like " hell" and i love it, but currently it is not incorporated in Domoticz.
It has a modbus RS 485 connection and so i orderd
https://nl.aliexpress.com/item/10050068 ... pt=glo2nld this Puser USR-DR132/134 modbus to ethernet convertor at Aliexpress.
I'am going to try to incorporate it in Domoticz.
There are already python tools available and the Homewizard Battery Plugin.
Any thoughts ?
Re: Marstek Battery plugin
Posted: Thursday 26 June 2025 13:42
by gizmocuz
It indeed supports modbus. So you could create a python Domoticz plugin for this.
Or a python application that runs in the background of your system and uses the Domoticz JSON API to publish it's values to Domoticz
Advertisement is a bit tricky... No it does not support 100A, as it is just plugged into your wall
The real max. output is 10.9A = ~2500 Watt (Default 800Watt)
(Which still is nice!)
Maybe this could help you get started:
https://github.com/gizmocuz/SDM630-Modbus
It is a Chinese Battery (Aren't they all), but they do ping-back to China.
Here is a Dutch review
https://www.youtube.com/watch?v=2HDamrcr1q8
Posted: Thursday 26 June 2025 13:54
by RNEE
Thank you !
I run it on a seperate group at 2500 watts.
Although i can programm (a little) , have some knowledge of I2C and SPI and C, python is not in my toolbox (!).
I will come back to this as soon as i receive the adapter.
Edit : found this
https://www.photovoltaikforum.com/threa ... /?pageNo=1
https://github.com/scruysberghs/ha-marstek-venus
Posted: Tuesday 08 July 2025 10:56
by RNEE
I have the Pusr DR134 (RS485 to LAN) running and posting values from the home battery to Mosquito.
(for the hardware setup thanks to " @superdupper1969" at Tweakers in the topic for connecting modbus to HA)
Although i have no experience in MQTT it was easy to set up the Marstek and DR134 and after some hours it have the device posting to Mosquito.
I now get the following message in MQTT Explorer :
{"params":{"dir":"up","id":"xxxxxxxxxx","r_data":[{"name":"batteryvoltage","value":"5426","err":"0"},{"name":"batterycurrent","value":"4373","err":"0"},{"name":"batterypower","value":"2374","err":"0"},{"name":"batterySOC","value":"54","err":"0"},{"name":"batterytotalenergy","value":"5120","err":"0"},{"name":"ACvoltage","value":"2341","err":"0"},{"name":"ACcurrent","value":"1045","err":"0"},{"name":"ACpower","value":"-2344","err":"0"},{"name":"ACfrequency","value":"4999","err":"0"},{"name":"internaltemp","value":"417","err":"0"}]}}
I have installed MQTTMapper (of witch i understand it should be usable to create devices) but now i do NOT get it how to create a device description for the homebattery in Domoticz.
There are no Homebattery device types on
https://wiki.domoticz.com/Developing_a_ ... vice_Types.
I could use some help on the JSON file for device description in MQTTMapper.
Posted: Tuesday 08 July 2025 23:52
by FlyingDomotic
A possible idea is to use some plug-in like MqttMapper.
I tried to make a configuration giving data posted here, but format is too complicated as the selector item is within a list (supported), but as value after "name" item. As of now, it's not supported, and there's no chance to support it soon, as the way definition is done is very uncommon (and not in JSON spirit).
Posted: Wednesday 09 July 2025 10:08
by waltervl
If the order in the list is always is the same, so eg batteryvoltage is always the first value in the r_data list you can use the order eg
params.r_data[0].value for batteryvoltage
params.r_data[9].value for internaltemp
Not sure how this could be used in the MQTT mapper JSON configuration file.
Posted: Wednesday 09 July 2025 11:57
by FlyingDomotic
waltervl wrote: Wednesday 09 July 2025 10:08
You're right, this is not supported.
As of now, only "*" is supported to scan a list of values, but idea is to be able to select an item, not an item's value.
"select" or "reject" are also supported, but to select or reject a message giving an item presence/absence, not to select an item in a list.
However, for this kind of complex syntax, yo can still copy the full message into a Domoticz text device, and do a manual parsing with either LUA or dzVents.
For example:
"My full topic message": {
"topic": "my/full/topic",
"type": "243", "subtype": "19", "switchtype": "0",
"mapping": {"item": ""}
Replace "my/full/topic" by topic of MQTT message you want to intercept and you'll get the original message into "My full topic message" Domoticz device (probably prefixed by "MQTT Mapper - " or equivalent).
You now can write a LUA or dzVents small script looking for this device changes, and analyze content of device (which is the full message indeed).
You may event extract only par of message specifying something into "mapping":"item". Here, instead of "", you may want to indicate "params/r_data" to only get the list of data.
Manually create corresponding (virtual) dummy devices, and load them within script.
Posted: Wednesday 09 July 2025 13:14
by RNEE
Thank you for your input, realy usefull.
Message is always the same, with changing values. Definition of the content of message is by me.
The DR134 asks the Modbus connected device and creats the message. It is very easy to setup, but one needs the registeradres.
I can limit the message to what i need :
batterySOC = percentage of battery filled
ACpower = watts going in or out.
i try dzVentz.
Posted: Wednesday 09 July 2025 14:14
by waltervl
RNEE wrote: Wednesday 09 July 2025 13:14
Can you also steer the structure of the content to make it more useable?
It ideally should look something like:
"params": {
"dir": "up",
"id": "xxxxxxxxxx",
"r_data": {
"batteryvoltage": 5426,
"batteryvoltage_err": false,
"batterycurrent": 4373,
"batterycurrent_err": false,
etc
Posted: Wednesday 09 July 2025 21:00
by RNEE
I tried several settings, but couldn’t change the layout.
Some conversion has to be made to get this layout.
The other setting is Modbus TCP so i probably can use another plugin.
Posted: Thursday 10 July 2025 2:15
by FlyingDomotic
Do you have any pointer to the doc explaining how to change layout?
Posted: Thursday 10 July 2025 10:34
by RNEE
The manuals are over here :
https://www.pusr.com/products/Lipstick- ... erver.html
Because i only need 2 values maybe it is possible to change Mqttmapper to read just 2 fixed values.
The other option is :
https://github.com/DomoticX/domoticz-mo ... me-ov-file
I looked into several different plugins etc but nothing that could fit easily.
The device is nice and usefull, it was very hopefull to have an easy solution but “helaas pindakaas”
Posted: Thursday 10 July 2025 11:47
by FlyingDomotic
What kind of MQTT publish transmission did you setup? Custom?
Posted: Thursday 10 July 2025 14:28
by RNEE
I use " Transparent transmission" , then the expected message is received :
{"params":{"dir":"up","id":"02103225061700034587","r_data":[{"name":"batterySOC","value":"67","err":"0"},{"name":"ACpower","value":"2492","err":"0"}]}}
I can upload a template file like this :
"datas": [
"key": 4,
"name": "batterySOC",
"sadd": 1,
"rtype": 3,
"radd": 32104,
"dtype": 1,
"magn": "1",
"report": 0,
"ampl": "0"
"key": 8,
"name": "ACpower",
"sadd": 1,
"rtype": 3,
"radd": 32202,
"dtype": 3,
"magn": "1",
"report": 0,
"ampl": "0"
It is like the input screen :
When set to " Custom" bytes are sent but i don't receive anything in MQTT Explorer.
But you mean a custom template can be made ?
Posted: Thursday 10 July 2025 14:47
by waltervl
From the manual
Transparent transmission: The data received by the serial port is
transparently transmitted to the associated topic.
Topic distribution: When configuring a topic, you can define an identifier
for the topic. After receiving serial port data, the device sends it to the
associated topic based on the identifier. The device allows different topics
to have the same identifier, so that data is pushed to all topics with the
same identifier. The identifier and the payload are separated by commas.
Custom mode: The custom mode is simple and quick to use, and users do
not need to configure the relevant parameters of data release on the web.
Only need to open the custom mode switch, click Save and restart
the device to achieve MQTT data transparent transmission.
So please try Topic distribution and the Custom to check the mqtt messages.
You have to restart the device after each change.....
Posted: Thursday 10 July 2025 14:50
by RNEE
Yes , yes i did.
I tried everything now. (also restarts etc).
No usefull output then.
I ask the company in china.
Posted: Thursday 10 July 2025 21:55
by RNEE
Found this using NodeRed to convert to a Domoticz usable message.
viewtopic.php?t=36213
Posted: Friday 11 July 2025 15:16
by Toulon7559
See several attempts to construct an interface between Marstek-battery and Domoticz and other applications.
But (whatever the application) a 'clean' setup starts with getting&reading the specification of the interface and it's data-protocol.
Therefore: which document is applicable for interface & data-protocol?
Posted: Friday 11 July 2025 16:26
by RNEE
I have converted the data delivered by the DR134 to Mosquito with JQ:
$ mosquitto_sub -t /PubTopic1/# -h 192.168.2.32 -p 1883 -u rene -P rene |jq -r --unbuffered '.[].r_data[0].value'|mosquitto_pub -t BatterySOC -l -h 192.168.2.32 -p 1883 -u rene -P rene
This returns the actual soc % to the topic "BatterySOC" or " ACPower" as a value in mosquito.
Now i have to figure out how to get it into Domoticz !
Posted: Friday 11 July 2025 16:37
by RNEE
Toulon7559 wrote: Friday 11 July 2025 15:16
I posted the manuals before.
The interface device DR134 automaticly polls the RS485 device and creates a MQTT message with a fixed layout witch is posted to in my case Mosquito as a broker.
So i thought it should be easy to incorporate into Domoticz, but "helaas pindakaas"
But Jq can handle the output now.
