Migrate RFXCOM to openMQTTGateway
MichelFrance
Domoticz version: 2023.1
Post by MichelFrance »
I am running Domoticz for a few years and I am very happy. Thanks to the developers and the forum members.
For now, I am using an RFXtrx433 usb to receive information from a few cheap thermometers or door sensors and to control my SOMFY blinds (RTS). I works but my house is quite large and my domoticz server is not in a central position: sometimes the RFXtrx433 miss some messages from the 433 devices and/or is jammed when sending a command to the Somfy blinds.
I decided to migrate from RFStrx433 to several ESP32 emitters/receivers in various locations.
For the Somfy blinds I use ESPSomfy-RTS (https://github.com/rstrouse/ESPSomfy-RTS) on an esp32 using MQTT (wifi + Mosquitto) to communicate with the domoticz server. It works fine!
For the various 433 thermometers and other devices, I use openMQTTGateway (https://docs.openmqttgateway.com/) on an ESP32 (I will use several of them in various locations of the house). It receive 433 devices signals and also send the values to domoticz using MQTT. I sends messages such as:
N: [ OMG->MQTT ] topic: home/OMG_multi_receiver/RTL_433toMQTT/Ambientweather-F007TH/2/154 msg: {"model":"Ambientweather-F007TH","id":154,"channel":2,"battery_ok":0,"temperature_C":25.05556,"humidity":63,"mic":"CRC","protocol":"Ambient Weather F007TH, TFA 30.3208.02, SwitchDocLabs F016TH temperature sensor","rssi":-51,"duration":215996}
or
N: [ OMG->MQTT ] topic: home/OMG_multi_receiver/RTL_433toMQTT/Nexus-TH/1/117 msg: {"model":"Nexus-TH","id":117,"channel":1,"battery_ok":1,"temperature_C":26.1,"humidity":56,"protocol":"Nexus, FreeTec NC-7345, NX-3980, Solight TE82S, TFA 30.3209 temperature/humidity sensor","rssi":-17,"duration":986996}
My problem is that for each real 433 device it creates 4 devices in domoticz:
1) Type=Light/Switch Subtype=Switch  Data=On or Off depending on the battery_ok value in the MQTT message above
2) Type=Humidity Subtype=LaCrosse WS2300 Data=humidity  in the MQTT message above
3) Type=General Subtype=Sound Level  Data=rssi in the MQTT message above
4) Type=Temp Subtype=THR128/138 THC138l  Data=temperature_C in the MQTT message above
for the same 2 433 devices received throught rfxtrx Domoticz had only 1 device for each:
Type=Temp+Humidity SubType=Rubicson/IW008T/TX95 (or Viking 02035, 02038, TSS320 for the second real device) Data=<the temp>+<the humidity> and reception bar=rssi value.
Any advice to group these 4 domoticz devices from the new (openMQTTGateway + MQTT) scheme in a single one as before with rfxtrx?
Re: Migrate RFXCOM to openMQTTGateway
There should be a config topic, or multiple config topics in the MQTT homeassistant folder for this device. These config topic decides what devices are created.
Can you post those config topics?
MichelFrance
waltervl wrote: Monday 23 June 2025 17:32 There should be a config topic, or multiple config topics in the MQTT homeassistant folder for this device. These config topic decides what devices are created.
Thank you for your help. Where do I find these config topics ?
See for example the wiki page https://wiki.domoticz.com/MQTT_AD_Report_Problems how to find and copy MQTT Autodiscover config topics.
MichelFrance
waltervl wrote: Tuesday 24 June 2025 11:01 See for example the wiki page https://wiki.domoticz.com/MQTT_AD_Report_Problems how to find and copy MQTT Autodiscover config topics.
Here they are:
homeassistant/sensor/Ambientweather-F007TH-2-154-humidity/config
{"stat_t":"+/+/RTL_433toMQTT/Ambientweather-F007TH/2/154","dev_cla":"humidity","unit_of_meas":"%","name":"Humidity","uniq_id":"Ambientweather-F007TH-2-154-humidity","val_tpl":"{{ value_json.humidity | is_defined }}","stat_cla":"measurement","device":{"ids":["Ambientweather-F007TH-2-154"],"cns":[["mac","Ambientweather-F007TH-2-154"]],"mdl":"Ambientweather-F007TH","name":"Ambientweather-F007TH-2-154","via_device":"OMG_multi_receiver"}}
homeassistant/sensor/Ambientweather-F007TH-2-154-rssi/config
{"stat_t":"+/+/RTL_433toMQTT/Ambientweather-F007TH/2/154","dev_cla":"signal_strength","unit_of_meas":"dB","name":"RSSI","uniq_id":"Ambientweather-F007TH-2-154-rssi","val_tpl":"{{ value_json.rssi | is_defined }}","stat_cla":"measurement","device":{"ids":["Ambientweather-F007TH-2-154"],"cns":[["mac","Ambientweather-F007TH-2-154"]],"mdl":"Ambientweather-F007TH","name":"Ambientweather-F007TH-2-154","via_device":"OMG_multi_receiver"}}
homeassistant/sensor/Ambientweather-F007TH-2-154-temperature_C/config
{"stat_t":"+/+/RTL_433toMQTT/Ambientweather-F007TH/2/154","dev_cla":"temperature","unit_of_meas":"°C","name":"Temperature","uniq_id":"Ambientweather-F007TH-2-154-temperature_C","val_tpl":"{{ value_json.temperature_C | is_defined }}","stat_cla":"measurement","device":{"ids":["Ambientweather-F007TH-2-154"],"cns":[["mac","Ambientweather-F007TH-2-154"]],"mdl":"Ambientweather-F007TH","name":"Ambientweather-F007TH-2-154","via_device":"OMG_multi_receiver"}}
homeassistant/binary_sensor/Ambientweather-F007TH-2-154-battery_ok/config
{"stat_t":"+/+/RTL_433toMQTT/Ambientweather-F007TH/2/154","dev_cla":"battery","name":"Battery","uniq_id":"Ambientweather-F007TH-2-154-battery_ok","val_tpl":"{{ value_json.battery_ok | is_defined }}","pl_on":"0","pl_off":"1","device":{"ids":["Ambientweather-F007TH-2-154"],"cns":[["mac","Ambientweather-F007TH-2-154"]],"mdl":"Ambientweather-F007TH","name":"Ambientweather-F007TH-2-154","via_device":"OMG_multi_receiver"}}
homeassistant/sensor/Nexus-TH-1-117-humidity/config
{"stat_t":"+/+/RTL_433toMQTT/Nexus-TH/1/117","dev_cla":"humidity","unit_of_meas":"%","name":"Humidity","uniq_id":"Nexus-TH-1-117-humidity","val_tpl":"{{ value_json.humidity | is_defined }}","stat_cla":"measurement","device":{"ids":["Nexus-TH-1-117"],"cns":[["mac","Nexus-TH-1-117"]],"mdl":"Nexus-TH","name":"Nexus-TH-1-117","via_device":"OMG_multi_receiver"}}
homeassistant/sensor/Nexus-TH-1-117-rssi/config
{"stat_t":"+/+/RTL_433toMQTT/Nexus-TH/1/117","dev_cla":"signal_strength","unit_of_meas":"dB","name":"RSSI","uniq_id":"Nexus-TH-1-117-rssi","val_tpl":"{{ value_json.rssi | is_defined }}","stat_cla":"measurement","device":{"ids":["Nexus-TH-1-117"],"cns":[["mac","Nexus-TH-1-117"]],"mdl":"Nexus-TH","name":"Nexus-TH-1-117","via_device":"OMG_multi_receiver"}}
homeassistant/sensor/Nexus-TH-1-117-temperature_C/config
{"stat_t":"+/+/RTL_433toMQTT/Nexus-TH/1/117","dev_cla":"temperature","unit_of_meas":"°C","name":"Temperature","uniq_id":"Nexus-TH-1-117-temperature_C","val_tpl":"{{ value_json.temperature_C | is_defined }}","stat_cla":"measurement","device":{"ids":["Nexus-TH-1-117"],"cns":[["mac","Nexus-TH-1-117"]],"mdl":"Nexus-TH","name":"Nexus-TH-1-117","via_device":"OMG_multi_receiver"}}
homeassistant/binary_sensor/Nexus-TH-1-117-battery_ok/config
{"stat_t":"+/+/RTL_433toMQTT/Nexus-TH/1/117","dev_cla":"battery","name":"Battery","uniq_id":"Nexus-TH-1-117-battery_ok","val_tpl":"{{ value_json.battery_ok | is_defined }}","pl_on":"0","pl_off":"1","device":{"ids":["Nexus-TH-1-117"],"cns":[["mac","Nexus-TH-1-117"]],"mdl":"Nexus-TH","name":"Nexus-TH-1-117","via_device":"OMG_multi_receiver"}}
On what Domoticz version are you running? As it should create combined temp/Hum devices on 2025 stable Domoticz.
MichelFrance
waltervl wrote: Tuesday 24 June 2025 18:03 On what Domoticz version are you running? As it should create combined temp/Hum devices on 2025 stable Domoticz.
About Domoticz
Version: 2025.1
Build Hash: 89d5c900d
Compile Date: 2025-05-05 09:02:49
dzVents Version: 3.1.8
Python Version: 3.12.3 (main, Jun 18 2025, 17:59:45) [GCC 13.3.0]
From this discussion it could be the Openhab auto Discovery setting as there is a "| is defined" in the value template definition. It could be Domoticz is failing on this.
viewtopic.php?p=297743
If this also is not helping please create a GitHub issue with all the requested info (partially you already gave it in this topic) so a developer can check what is going on. The +/+ issue as mentioned in the old discussion was already solved in 2023.
