Errors since last 4/5 updates: "Climate device invalid/unknown preset_mode received! (ESPclimateAirco: none)"
BarryT
Domoticz version: 2024.3
Post by BarryT »
i'm seeing this error messages in my log from the mqtt auto discovery since a couple of weeks.:
2025-06-14 16:47:34.812 Error: MQTT-AD: Climate device invalid/unknown preset_mode received! (ESPclimateairco3: none)
2025-06-14 16:47:35.629 Error: MQTT-AD: Climate device invalid/unknown preset_mode received! (ESPclimateairco2: none)
2025-06-14 16:47:36.445 Error: MQTT-AD: Climate device invalid/unknown preset_mode received! (ESPclimateairco1: none)
2025-06-14 16:47:37.260 Error: MQTT-AD: Climate device invalid/unknown preset_mode received! (ESPclimateairco5: none)
2025-06-14 16:47:38.076 Error: MQTT-AD: Climate device invalid/unknown preset_mode received! (ESPclimateairco4: none)
I did not changed anything as only updated zigbee2mqtt and domoticz to its latest versions.
What is going wrong here?
I'm not getting the core problem into these weird error messages because all these ESPHome devices works for 2/3 years and never updated them.
Also never had (and having) any issues.
gizmocuz
Re: Errors since last 4/5 updates: "Climate device invalid/unknown preset_mode received! (ESPclimateAirco: none)"
Post by gizmocuz »
Could you create a github issue, and post the MQTT config topic+payload, as well as the status topic/payload?
And use this instruction to report this issue https://wiki.domoticz.com/MQTT_AD_Report_Problems
BarryT
Post by BarryT »
I created an issue on github, thanks Walter and Gizmo!
BarryT wrote: Monday 16 June 2025 20:35 I created an issue on github, thanks Walter and Gizmo!
But you forgot to add the requested data in the issue: https://github.com/domoticz/domoticz/issues/6353
BarryT
Post by BarryT »
waltervl wrote: Friday 20 June 2025 0:30
Could you please take a look into the last reply?
Is it what you looking for, otherwise can you tell me what exactly do you need to debug?
r0r1
Post by r0r1 »
Just to let you know, that also noticed this after updated domoticz to 2025.1
Climate device invalid/unknown preset_mode received! (0xcc86ecfffe7db798_fan_zigbee2mqtt: [object object])
journalctl -u zigbee2mqtt.service -f
Jul 26 14:23:02 DietPi npm[1162378]: Zigbee2MQTT:info  2025-07-26 14:23:02: MQTT publish: topic 'zigbee2mqtt/AirPurifier', payload '{"air_quality":"unknown","child_lock":"UNLOCK","fan_mode":"[object object]","fan_speed":0,"fan_state":"ON","filter_age":73053,"led_enable":true,"linkquality":189,"pm25":-1,"replace_filter":false,"update":{"installed_version":65587,"latest_version":69633,"state":"available"},"update_available":true}'
BarryT
Post by BarryT »
