get_gas_values(domoticzurl, domoticzdeviceid_gas) stopped working
Posted: Saturday 14 June 2025 9:15
by prutsky
I'm running two scripts which uses "get_gas_values(domoticzurl, domoticzdeviceid_gas)". These scripts worked fine until May 6th 2025.
Now I get the following error:
/domoticz/scripts $ python3 gasstanden.py
  File "/home/pi/domoticz/scripts/gasstanden.py", line 52, in <module>
    GasMeterReading = get_gas_values(domoticzurl, domoticzdeviceid_gas)
  File "/home/pi/domoticz/scripts/gasstanden.py", line 39, in get_gas_values
    device_data = Domoticz(url).get_device(device_id)
  File "/home/pi/domoticz/scripts/gasstanden.py", line 31, in get_device
    data = json.load(self.__execute__(url))
  File "/home/pi/domoticz/scripts/gasstanden.py", line 24, in __execute__
    return urllib.request.urlopen(req, timeout=5)
  File "/usr/lib/python3.11/urllib/request.py", line 216, in urlopen
    return opener.open(url, data, timeout)
  File "/usr/lib/python3.11/urllib/request.py", line 525, in open
    response = meth(req, response)
  File "/usr/lib/python3.11/urllib/request.py", line 634, in http_response
    response = self.parent.error(
  File "/usr/lib/python3.11/urllib/request.py", line 563, in error
    return self._call_chain(*args)
  File "/usr/lib/python3.11/urllib/request.py", line 496, in _call_chain
    result = func(*args)
  File "/usr/lib/python3.11/urllib/request.py", line 643, in http_error_default
    raise HTTPError(req.full_url, code, msg, hdrs, fp)
urllib.error.HTTPError: HTTP Error 404: Not Found
The Python code which worked fine before is:
import sys
import json
import urllib.request, urllib.error, urllib.parse
import re
import time
import datetime
import http.client, urllib.request, urllib.parse, urllib.error
def open_port():
    pass
def close_port():
    pass
class Domoticz():
    def __init__(self, url):
        self.baseurl = url
    def __execute__(self, url):
        req = urllib.request.Request(url)
    def get_device(self, xid):
        Get the Domoticz device information.
        url = "%s/json.htm?type=devices&rid=%s" % (self.baseurl, xid)
        return data
def get_gas_values(url, device_id):
    Get gasmeter reading.
    data = device_data['result'][0]['Data']
    ex = re.compile('^([0-9\.]+)$')
    groups = ex.match(data).group
    gasstand = float(groups(1)) #/ 1000
    return gasstand
# example usage
domoticzurl = "http://192.168.2.44:8084"
domoticzdeviceid_gas = 10
print ("Gasmeterstand:\t\t\t\t"+str(GasMeterReading).replace('.',',')+"m3")
# creeer een bestand met de waarde / create a file with the readings
name = '/home/pi/domoticz/scripts/gasverbruik.csv'  # Naam tekstbestand / Name of text file
now = datetime.datetime.now()
try:
    file = open(name,'a')   # create file / creeer bestand
    file.write(str(now.strftime("%Y-%m-%d %H:%M")) + ';' + str(GasMeterReading).replace('.', ',') +'\n')
except: # something went wrong / in het vorige blok is iets niet goed gegaan (error)
    print('Something went wrong!')
What am I missing that this ain't working anymore?
Re: get_gas_values(domoticzurl, domoticzdeviceid_gas) stopped working
Posted: Saturday 14 June 2025 10:18
You are using deprecated API calls in the script.
For example
will be
/json.htm?type=command&param=getdevices
See the wiki how to solve it:
https://wiki.domoticz.com/Domoticz_API/ ... and_newer)
Posted: Saturday 14 June 2025 13:49
by prutsky
Thanks for clearing that out! I got this working:
        url = f"{self.baseurl}/json.htm?type=command&param=getdevices"
        return data
    print (data)
The output is changed also it seams. I now get the next error:
10281666;9519876;2372162;5242921;365;0
  File "/home/pi/domoticz/scripts/gasstanden.py", line 51, in <module>
  File "/home/pi/domoticz/scripts/gasstanden.py", line 43, in get_gas_values
AttributeError: 'NoneType' object has no attribute 'group'
Sorry my Python skills are limited...
Posted: Saturday 14 June 2025 22:12
by prutsky
I found out my get_devices call was not correct (not using the xid).
The correct one is: url = "%s/json.htm?type=command&param=getdevices&rid=%s" % (self.baseurl, xid)
